Originally posted by osv roger kludged e-mount lenses into working on his bench, but he had to add a layer of optical glass to the rig
yeah, I would never do that, but Rodger had good reason for it: I saw the MTF results without the glass, and they were atrocious. For some reason SONY use a very thick sensor stack, so there was a need to emulate it through the addition of a planar glass surface near the exit pupil.
Originally posted by osv the problem with optical benches is that they only test at infinity; afaik, it's difficult if not impossible to optimize a lens for both infinity and mfd, so if you are shooting at less than infinity, the bench probably doesn't represent what the lens is actually doing.
At lensrentals they use an OLAF bench, which is vertical. My Zeiss bench is horizontal, this gives it greater flexibility with which lenses that can be placed on the lens mount platform as it can be moved to allow for testing the lenses at different focus distances and it also allows for unusual lenses such a superwides such as the Canon 11-14mm f/4L and Sigma 8-16mm to be tested and it can also handle lenses as long as 1200mm*. But like everyone elses bench, mine freaks out when you put a fisheye lens on the platform.
Originally posted by osv roger uses imatest all the time,
But that isn't all he uses.
*Which are relatively common in the world of large format.
