Originally posted by Digitalis Which was my point all along, Sony as usual, is being flat out deceitful.
no, as i posted earlier wrt imatest and dcraw, sony in-camera lens corrections for raw files can be turned off, if the raw developer software has that capability, the raw data itself is not affected, because the correction data for raw files is written into a separate parameter... see these two links, from the same author:
"I think you’re mixing 2 different things. I believe Jörg’s diagram is correct.
– LR takes its lens distortion correction from its database of lens-profile files. That’s what you’re applying in the “Lens Correction” module.
– However, Sony also embeds its own lens correction information in the ARW-file (SR2SubIFD tag 0x7982, mirrored in Exif SubIFD tag 0x7037 – it’s written independently of your off/auto setting for distortion correction), which LR then chooses to completely ignore. Interestingly, when you run the ARW through Adobe’s DNG-converter, it writes the information into an XMP-tag (“LensDistortInfo”). Meaning, it does read the information but doesn’t use it.
For CA, it’s the opposite. The equivalent tag in the ARW is always interpreted by LR, no matter your camera setting.
I documented my findings on this a while ago at
https://variousphotography.wordpress.com/ if anybody is interested in digging deeper."
In-camera lens compensation | JÖRG HAAG
"Here’s a summary of what I’ve found on regarding the lens-correction data that Sony embeds in their ARWs. This is tested with a Sony A7 (ILCE-7) and the Sony/Zeiss 35mm F/2.8 and 55mm F1/1.8 lenses. I would believe that this also holds for other cameras using v2.3.1 of the ARW format (e.g., A7r, A7s, A7m2) but haven’t tested it.
The A7 allows to separately set 3 possible corrections in the menu (‘Auto’ vs ‘off’).
Vignetting correction
Chromatic Aberration correction
Distortion correction
Not every lens seems to support all modes, my 55mm has the distortion correction greyed out to ‘Auto’, so it can’t be switched off.
However, Sony is embedding the data into the ARW in any case anyway, no matter the setting (at least for CA/dist, probably also Vignetting). It’s up to the software to decide if to use it.
Also interesting is Adobe’s take on this:
Lightroom automatically applies CA correction and the DNG-converter writes CA-correction opcodes into the DNG-file.
Distortion correction is not applied in Lightroom. However, the DNG-converter writes an non-standard XMP-tag into the DNG-file that saves the decoded correction data. It does not write distortion-correction opcodes (although they’re part of the DNG-spec), so other DNG-readers won’t apply lens-correction either (unless they interpret Sony’s MakerNotes on their own).
As far as I can tell, Lightroom and the DNG-converter completely ignore any Vignetting correction information.
---------- Post added 02-18-16 at 10:28 AM ----------
Originally posted by Digitalis 1) you don't lose as much resolution when you apply lens corrections in post
sony raw lens corrections are always applied in post, the camera does not alter the actual picture data itself, see above.
