I have a request for information which, hopefully, somewhere around here is capable of providing.
For a backstory, I have a Sony a5000 which is a compact mirror-less thingy with sony E-mount and APS-C size sensor. I have also a Pentax K-x and a small number K, KA and KAF2 mount lens including a relatively recent addition of few legacy Pentax manual primes. After buying the Sony (as a replacement for a point and shoot that broke as a "mobile" camera) I stumbled in the net upon a thing called a focal reducer which, in essence is supposed to be a "reverse teleconverter" by providing approx 0.72x magnification by focusing light which should fall on full frame size from legacy lens down into an APS-C size which, in essence, gives one a bit wider view more similar to "full frame" size and a bit more light focused into the APS-C size. I have read about these for a little while but there seems to be not much information about these out there. What surprised me on a5000 was that the focus highlight seems to make using manual lens a lot more viable (with a simple mechanical adapter) than on a K-x with the default focusing screen (I just ordered a split screen for better focus for K-x as well but this one will take a while as its shipping all the way from China).
As far as I understand the situation with the two mentioned above is following. First iterations had some flare issues if a bright light source was in the picture. Lens Turbo II is in a nutshell Chinese premium brand thingy and is second iteration which supposedly has addressed the flare issues by using better coatings on the rear elements. Camdiox is a German brand but a bit simpler and cheaper. As the price difference between the two would be about 35 EUR (in favor ow Camdiox) I would be content to go with Lens Turbo II (which is supposed to be optically a bit better as its the second iteration), however, the catch is that they redid the mounting system when they re-engineered their adapter so it now has non-trivial mounting system.
So anyone here has a Lens Turbo II and cares to share his/her experience with it? How reliable is the mounting system in your experience/opinion? Can I lave the adapter on the body while I switch the lens or should I remove the adapter, mount it on the lens and then attach the whole thing to the body every time I change lens? Out of the two mentioned this one seems to have few reviews but almost all of these seem to go over the mounting system rather briefly skipping straight to optical quality. Which is supposed to be better now than the previous version. No direct comparisons with Camdiox unit as far as I'm aware.
Camdiox one seems to be a bit less common as there is almost no reviews for it and just few blog or forum posts. No one seems to think the mounting system needs any scrutiny and as far as I understand it is a straightforward thing. Just twist it in the E mount bayonet until it clicks and you can leave it on the body and switch lens on it as much as you want need? Would be great if anyone in here would be able to provide some insight into the experience of actually using one of these.
Or if there is any others which you would feel worthy of recommendation or highlighting I'm interested in these as well. Metabones (the original thing) is beyond my budget but something under about 150 EUR or so is still acceptable. for reference, Camdiox would be 95 EUR for me and Lens Turbo II is about 130 EUR for me. I would specifically like something that I can leave on the body while out in essence "sealing" it and reducing hopefully substantially probability that some stuff manages to stick to my sensor while I switch lens. After all mirrorless does not have a mirror covering the sensor so any time lens comes off the sensor is directly exposed to the nature and elements.
