Originally posted by iss2012 This part intrigues me
"It is interesting to compare the relative diameters of various mounts:
Minolta/Sony A mount AF system diameter: 49.7mm
Sony E mount diameter: 46.1mm
Fuji X mount diameter: 44mm
Canon EOS EF mount: 54mm
Pentax K mount: 44mm
From this you can that see Sony were better off putting IBIS into their A mount, which has a wider diameter, because it is more of a dedicated full frame mount, not an APS-C mount. You can also see that both Sony and Pentax are adding IBIS to excessively narrow mounts purely as a marketing ploy, with flagrant disregard towards optical fundamentals. It represents the victory of advertising over engineering."
Is it true that pentax is making a compromise on image quality especially on the corners ?
This has been discussed elsewhere on the Forum. Unless Fuji users have had unique access to the K-1, and discovered something that others here haven't, I don't see how they can credibly claim that Pentax K-mount cameras are compromised by IBIS. The K-mount was, of course, designed to cover a full 35mm frame, not just an APS-C frame.
The sensor movements necessary to implement successful IBIS are not as great as some would have us believe, and the only question about potential clipping (not really "image quality") in the corners relates to some older lens designs, whose image circles may be too small to use IBIS without it occurring.
We'll all get to see for sure when the K-1 arrives, but this quote looks like marketing FUD, to me.
