Originally posted by tomO2013 If you want to see it in liveview, go into liveview and do the same with spot metering as you would do with your A7. You will see the result of the point that you have the spot pointed over and how the camera has metered for medium grey. Then dial in +/- exposure comp as needed.
that only works if the camera has wysiwyg capability, which most pentax cameras do not.
again... wysiwyg and liveview are not the same thing, it's two entirely different concepts:
https://en.wikipedia.org/wiki/Live_preview
---------- Post added 05-11-16 at 10:36 AM ----------
Originally posted by UncleVanya I mostly trust the camera to be close but there are certain times I chimp and adjust. I don't trust the preview on my mirrorless yet.
that's a wise approach, if the camera doesn't have wysiwyg capability.
Originally posted by UncleVanya As for EVF's not all are OLED and OLED isn't without faults.
i suspect that just about all evf displays these days are oled:
Digital cameras with OLED displays | OLED-Info
"OLED displays have the following advantages over LCD displays:
Improved image quality - better contrast, higher brightness, fuller viewing angle, a wider color range and much faster refresh rates.
Lower power consumption
Simpler design that enables ultra-thin, flexible and transparent displays
Better durability - OLEDs are very durable and can operate in a broader temperature range"
