09-19-2016, 03:14 AM   #16
Removing the mirror does allow for a lot shorter registration distances and that has its own set of strengths and weaknesses.
I am not a lens designer, but my understanding is that your smallest lenses will be at focal lengths close to the registration distance. That is why the DA 40 is so small and why the smallest Sony FE lenses should be smallest around 18mm (they don't have any FE primes at this focal length at this point). Lens designers can make choices not to clean up aberrations or, to have slower apertures and these will also tend to have a smaller lens.
With zooms, mirrorless just doesn't offer a whole lot of advantage. The G master 24-70 is 87.6 by 136mm with a weight of 886 grams while the Pentax 24-70 f2.8 is 88.5 by 109.5mm in size with a weight of 787 grams. Certainly at a minimum, when it comes to zooms, you can safely say that if they are of similar quality and cover the same focal lengths, they will be similar size (if not bigger) on mirrorless compared to lenses designed for SLRs.
09-28-2016, 05:03 AM   #17
K-9
Sony may have got it wrong, but I'd love a Samsung FF mirrorless. Their lens lineup is superb, and not long like the Sony lenses.
What I can't believe is how big the new Sigma 85mm f1.4 art lens is! Way too big. 86mm filter?!? C'mon.
lens, lens size comparison, mirrorless
Comparison shots between 645D/645Z and K1 richmondthefish Pentax Medium Format 34 07-16-2016 11:12 AM
Image noise in DSLRs and mirrorless cameras... Ventzy Photographic Technique 21 03-30-2016 11:07 AM
Comparison between the 2x T6 and late 2x telecoverters? cooltouch Pentax Medium Format 4 12-07-2014 05:03 PM
43mm and 70mm limited size comparison shaolen Pentax SLR Lens Discussion 7 09-30-2013 09:10 AM
K-5 Size and Weight Comparison Heie Pentax K-5 & K-5 II 5 01-03-2012 06:34 AM
All times are GMT -7. The time now is 07:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
