Originally posted by UncleVanya I am afraid we don't know your market. I would have said the Nikon D600 or so would be the best compromise. I am shocked that a 12mp FF is adequate for weddings given the large size prints favored by brides. But in thinking about it I guess it makes reasonable sense as long as you don't have to crop much.
Yep 12MP is fine with minimal cropping that is. And we do not do large prints here. Mostly stills are incorporated into photobooks with print sizes not bigher than 16R. What really shines here are the actual presentations of the event highlights via SDE on both stills and videos
---------- Post added 01-04-2017 at 04:58 AM ----------
Originally posted by BigMackCam A question... given that your potential clients expect you to have a full-frame camera rather than APS-C, isn't there a risk that they'll also expect you to have the standard two zoom lens kit of a 24-70 f/2.8 and 70-200 f/2.8? I wonder what they'd make of you turning up with a couple of relatively small-to-mid-sized primes. You may want to check if there are any expectations on lenses before you make a decision...
EDIT: That leads me to another question... If you're planning to take paid wedding assignments where clients expect full-frame, won't you need a backup body too? What happens if your only full-frame camera dies or develops a fault? You need to be able to keep shooting otherwise you'll have very unhappy clients. You could, of course, take your K-30 and a couple of K-mount lenses with you, but that's APS-C format. Again, worth thinking about...
Unfortunately the photographers were the ones "requiring" to bring FF. It's like, we won't let you into this we'll rather choose those with FF.
As for lenses, of course those fast zooms are mandatory. I have those lens equivalent in apsc and will be paired with my Pentax as back up. But I need to start somewhere in FF. And in most cases (IMHO, 35 and 85) can be sufficient specially if that suits one's shooting style and would prefer to go minimalist. I can also benefit from others as they can lend some of theirs during gigs and eventually I can save some to own those.
I would really want to use Pentax FF. But I cannot afford it now, either I save up some more and lost possible gigs along the way or make a detour by taking another format in another system.
Thank you guys for all your input
---------- Post added 01-04-2017 at 05:23 AM ----------
Originally posted by jatrax If you are stuck on FF then I would suggest you talk to those studios that might hire you. If they are limiting second shooters to FF cameras then I suspect they also want you to use the same brand so the RAW format is the same and you can use their lenses if needed.
Obviously I do not know your market but perhaps you should do more research there before asking general questions on a forum. I am skeptical about the "only FF" thing. At the last 6 or 7 weddings I have attended I saw no FF cameras at all. All paid photographers were using APS-C bodies. Perhaps there was a time when a FF body was clearly better but that is no longer the case. Particularly when comparing an older FF to a modern APS-C.
I am also surprised at your lens choices. Most pros I have seen working are using a combination of zooms not primes. But again I do not know anything about your market. Perhaps you could stop in and talk to 3 or 4 photographers that might hire you. Find out if they are interested, what they would need to see from you to hire you, what gear they require and so on. You need to make those contacts anyway so it seems to be a good place to start rather than buying gear that might be wrong.
Thank you for the time and iput. Everyone knows, specially with the advancement of technology, apsc CAN deliver good images with proper technique and skills of the photographers. It is just that there is a thinking here that shooting with FF is better than APSC specially in handling DoF and noise
