Originally posted by rawr SkyFire blues.
I agree that you prob shouldn't have used a TC. It's another layer of glass, dimming the DA*300mm to f5.6 wide-open (or f8 FF equivalent, I guess), and it adds another set of electronics for the camera and SDM to fight against.
Actually your confused here, for exposure, ƒ5.8 is not ƒ8 on full frame. For exposure ƒ5.6 is ƒ5.6 on any system 8x10 film or on your Q. When discussing AF DoF equivalence is irrelevant. For 90% of shooting DoF equivalence is irrelevant.The fact it is even called equivalence is a lie in itself. It applies only to DoF, in DoF critical images. It should be called Depth of Field equivalence. There' no need for for a term like exposure equivalence, or mentioning that most AF systems are turned to ƒ2.8, regardless of sensor size because most of us understand those things. Or at least used to before these "equivalence" freaks started pretending that depth of field is all tha matters. It's one of three factors to consider when adjusting aperture, and for most of us the least important.
But, your point that your AF doesn't function as well with at ƒ5.6 as it does at ƒ2.8 is real consideration. But that is only a low light consideration. Every lens I own, even the 60-250 with the 1.7 at ƒ6.3 focusses well in daylight. It shouldn't have been a problem. The issue I seem to face more often is my ability to follow the object in the viewfinder is so unsteady that the camera doesn't seem to have time to lock on given object. There is room for human error here. But it's also possible that the refresh cycle on a Nikon or Canon would be enough faster that it could lock even though I'm not that steady. All I ever see on these kinds of issues is a lot of speculation.
The trouble is, for this kind of shot, I don't know how to eliminate human error for testing. Without that, I wouldn't even venture an opinion.
I would start with establishing tha no one shooting Canon (or Nikon) for the camera model I'm interested in has these kinds of issues. Ian and I did a shoot off a while ago with dogs running straight at us. If memory serves me well I had about a 60% keeper rate I was using my K-3, he had a 90% keeper rate. But the difference in AF performance wasn't enough to explain your results. IN fact the K-3 did fine at a distance, it was only as the dog got close to the camera the K-3 had problems, Ian's Nikon was able to keep up even at close range. That may be as much a function of lens design as it is the cameras AF system. But of course that's irrelevant. Pentax is really late to the game, and only with the 3 DFAs and the PLM have they even tried to build lenses with any fast AF capability.
If you are talking speed of AF and you don't own one of those lenses, one of which is actually quite inexpensive, but you are planning to go out and buy a Canon with a fast focussing lens, you haven't given the Pentax a fair shot. For the cost of a 55-300 PLM you might be happy.
I've used SDM (and a DC lens) long enough I shudder when ever I see "fast AF" and SDM in the same sentence. It's virtually 100%, someone is disappointed. SDM being so slow is the biggest reason the DFAs have done so well. At least from an action shooter's perspective. For 90% of what you do, SDM is just fine.
