Originally posted by Tatouzou Best is to have 1 or more extra batteries, whether OEM (when affordable) or third party generic.
Yes. Note: Pentax D-LI90 is actually smaller than it's charger and power cable. 1 spare pre-charged battery is the best.
Originally posted by Tatouzou I never used the USB port on my cameras to transfer data, it is so easy to insert the SD card in my laptop, and the transfer rate this way is lightning fast.
I do the same :-) insert SD card in laptop SD card slot, that's faster, one can even browse images on the SD card itself and copy only the interesting ones to HDD. Eventually there are cheap USB3 SD card readers that work faster than camera USB itself.
Originally posted by Tatouzou I have several SD cards, they are cheap if you are not a video shooter and dont need the ultimate speed and capacity: any class 10 SD card I experienced was fast enough for still bursts or full HD video capture.
Yes. Agreed. Actually, due to the speed limitation of the K1 (or K3) there is no point of buying ultrafast SD cards that cost more. I prefer to buy Transcend 300x or 600x that are fast enough but much cheaper than the fastest ones, and the advantage is I can use those SD as intermediate storage for when I don't have time to transfer photos immediately, keeping the task of sorting out photos when the weather will be bad.
Originally posted by Tatouzou I feel safer with several smaller cards than fewer high capacity cards.
Sure, in case one SD card book is corrupted or whatever, it's less risky to use multiple smaller SD cards vs using a single large expensive one.
Originally posted by Tatouzou As for me I dont understand the need of 4K video
Well, when shopping, we went on discussing the matter in front of large size flat panel display HD and UHD with the sales guy of the electronic appliance retailer (Fnac etc). There was a 4K UHD being played , and we have to look really really close to perceive any small difference between the HD display and the UHD. Actually, at 1 meter distance , no one could tell the difference between the HD and UHD. We ask the sales guy why would we buy the 4K, he replied that it's because it's the trend...
Originally posted by Tatouzou rather aims to produce a good quality video, it needs lots of accessories (think about tripods, sound recording and lighting/reflectors for instance), a good enough scenario and script, hours of capture, with at least one or two friends to help the cameraman, and lots more work in cutting and PP
Most users complaining about Pentax video, recorded video handheld, shaking the camera to show the effect of rolling shutter, which is precisely what pro don't do because shaky images, even only slightly shaky , destroys the comfort of video watching.
Pro videographer use , as you mention, accessory, the camera is steadily mounted on a panning head and / or rail to ensure smooth motion while changing the view point. Mounting a Pentax DSLR on such video specific equipment and no one can tell if it was recorded with a Pentax or any other brand. As you mention, scenario creation, transitions between scenes, background music count much more then the camera used. Then there can be an issue of data rate of the bit stream produced by the Pentax DSLRs, but that can be compressed by the software used to render the video. Video is a discipline on its own, it's a lot of work and require specific skills, blaming the camera is way too easy. There are lot of crappy videos out there, recorded with DSLR supposedly good for videos...
