Originally posted by JohnBee With respect to individual monitor profiling and the likes, it's best to take measures to properly identify such things before drawing conclusions. One good example of this is when 30bit displays came into the scene, so many photographers(myself included) came to see just how much of the gamut we were missing. And so, I'd recommend taking the safe route when others do not share in the same conclusions insofar as on screen exposure clipping is concerned. To which I'd add, and with respect to the image in question, it would appear that the photographer processed the image with highlights in mind as the only apparent blowouts that were coming-up on my screen are on a small portion of the right sock. Whereas the face and fabric etc. are all showing color information (on my own screen that is)
Oddly enough low key photography seldom need a lot of DR to capture the full tonal values intended for the scene when displayed, the places you need DR is where you have HDR scenes where you want to lift or for the better word shift the DR captured in the raw that are located in shadows and place them in the mid tone zones for the displaying device, be it print or screen.
With low key photography you seldom lift or shift any of the shadows,if anything you are setting the black point very high up in the top end of the DR data a cameras sensor can capture. This is due to the fact that we are using high contrasts to convey the scene.
Most of the time we see clipping in LKP it was the intent of the photographers processing to use the full range of the tonal gamut of the display device to convey their artistic eye. There is no written law that it is Wrong to having 0,0,0 and 255,255,255 any where in the final image
With LKP many like to clip and place any reflective surfaces at 255,255,255 as they would look unnatural as gray or off white, this can included any reflected light from the shiny surface of flat black ca,r to the glistening found in black hair and even how skin natural creates micro reflective surfaces from harsh light sources.
Even when using controlled lighting for work you can see how skin acts as a shiny little surfaces that can reflect light just like a silver surface
The only time we do not what to see any clipped data is in the raw file in areas where we want to contain some light data for processing , heck there is also no written law that the raw file must contain all of scenes DR at the top end with no clipping if the photographer chooses there to be clipping. Placing the exposure such that there was no clipping in the reflective surface of the lips would be a waste DR of the raw file, it was best to use that DR for the areas where I what the camera to capture the most amount of data from the scene above
