Originally posted by manufocus Gladly, so I'm thinking the olympus has the newer sensor and better IS so hopefully I will end up with roughly the same low light capabilities as with the K30.
As Lenses I'm looking for the Lumix 25mm f1.7 as main lens. Probably going for a 35mm FF equivalent later on. Also have to check size of the 25mm/1.7 to see if it fits or if I have to go pancake.
This would pretty much fullfull my needs in flexibility retaining the option of getting a long lens but also having full dslr capabilities in a much smaller/lighter package.
Any comments appreciated.
I have the 20mm f/1.7 Lumix and like it but it is slow to focus which is a common complaint. I have never used the 25mm f/1.7 Lumix. The 42.5 f/1.7 Lumix I have is very fast and reasonably small. I have a GX-1 and a GX-7. I found the 2 axis GX-7 Image Stabilization to be surprisingly effective even with adapted lenses. The GX-7 sensor works well to about 1600, 3200 is pushing it a bit. I found the K-3 better at 3200. Sorry I don't have any direct Olympus experience that is relevant. I have used some of the lenses and a long time ago I played with a couple of friends bodies but I never warmed to them. The Panasonic menu structure always made more sense to me.
---------- Post added 11-19-17 at 12:26 PM ----------
Here's a size comparison for you:
http://j.mp/2ivHgbT
OMD-EM5 MKII with 25mm f/1.7 Lumix
GX-1 with 20mm f/1.7 Lumix
GX-7 with 42.5mm f/1.7 Lumix
The latter two are for you to know what I am using for comparison. You can swap in other bodies and lenses as you want on this site to get a good idea of sizes.
