09-03-2018, 07:10 PM   #76
I thought mf (ones in 645z and 50s) is around 30% larger than ff.
FF is 36x24...(864sqmm)...crop MF is 44x33(1452)...to be accurate its 68% larger.
09-03-2018, 09:00 PM - 2 Likes   #77
Mark Ransom's Avatar
QuoteOriginally posted by surfar Quote
You need to be careful about whether you're talking linear or area measurements.
Linear measurements are usually compared by the diagonal of the sensor. FF=43.3mm, crop MF=55mm, so the ratio is 1.27. 27% larger.
Yes, the area is 68% larger.
09-03-2018, 09:05 PM   #78
59.5% larger
1452mm2 x 0.595 =864mm2
The area difference really boils down to the final image ratio, if you are to use 4x3 then 645 has a much larger area than FF and if you are using 16-9 or 3x2 then the size difference is much smaller
09-03-2018, 09:22 PM   #79
QuoteOriginally posted by Ian Stuart Forsyth Quote
59.5% larger
Your math is wrong. When you say something is some percent larger than something else, the smaller one is the base. 864 + (68% * 864) = 1452.
09-03-2018, 09:24 PM   #80
QuoteOriginally posted by Mark Ransom Quote
Ya beat me to my correction you are correct
09-03-2018, 09:29 PM   #81
59.5% larger
The FF is the crop factor one...determining how much larger means the bigger dimension must be divided by the smaller.
The sensors are rounded to the closest full number as well...i cant be bothered getting the exact dimensions...
But MF crop sensor has around 70% more area to catch light....Thats a simple explanation.
09-04-2018, 11:07 AM - 1 Like   #82
vZwicky's Avatar
I was told there would be no math.
09-04-2018, 11:49 AM   #83
retired sw engineer
reh321's Avatar
59.5% larger
You need fairly accurate numbers - otherwise you're calculating with garbage,
If something has 70% more area, then its area is 1.7 times larger.
If area is 1.7 times as large, the linear dimensions are sqrt(1.7) = 1.3 times as large, or 30% larger.
On the other hand, if length and width is each 59.9% larger, then they are 1.599 times as large,
and the area would be (1.599)(1.599) = 2.5568 times larger, or 155.68% larger.
The numbers in your post are not even close to being consistent.
09-04-2018, 01:32 PM   #84
QuoteOriginally posted by reh321 Quote
They're not consistent because you're assuming the aspect ratios are the same. FF is 3:2 while MF is 4:3. That's why you compare the diagonals instead of the width or height for the linear measurement. Of course for area measurements the aspect ratio doesn't matter.
09-04-2018, 03:26 PM   #85
Oh, well...i'll put some photos up ...my MF next to my FF,hows that?...You wanta do the same?
09-04-2018, 04:12 PM - 1 Like   #86
vZwicky's Avatar
Okay, so theres math. I'll take a stab at it. My findings will be in agreement and disagreement with previous posts. All measurments rounded to the nearest millimeter. Fuji's medium format sensor: 44mm x 33mm (4:3 aspect ratio). Full frame sensor: 36mm x 24mm (3:2 aspect ratio). It Pythagoras was not wrong, their respective diagonal measurements are 55mm and 43mm. The medium format sensor has a 28% longer diagonal- a useful metric for calculating crop factor. It's 22% wider on the x axis, and 37.5% taller on the y. What really counts for gauging image quality between the two, imo, is overall surface area. At least insofar as image quality is influenced by sensor size. The MF sensor has an area of 1452 square millimeters, vs. 864 square millimeters for the full frame sensor. The medium format sensor is 68% larger.
09-04-2018, 04:18 PM   #87
QuoteOriginally posted by vZwicky Quote
Okay, so theres math. I'll take a stab at it. My findings will be in agreement and disagreement with previous posts. All measurments rounded to the nearest millimeter. Fuji's medium format sensor: 44mm x 33mm (4:3 aspect ratio). Full frame sensor: 36mm x 24mm (3:2 aspect ratio). It Pythagoras was not wrong, there respective diagonal measurements are 55mm and 43mm. The medium format sensor has a 23% longer diagonal. It's 22% wider on the x axis, and 37.5% taller on the y. What counts, imo, is overall surface area. The MF sensor has an area of 1452 square millimeters, vs. 864 square millimeters for the full frame sensor. The medium format sensor is 68% larger.
Only one thing I disagree with, and I think it's probably a typo: 55/43 = 1.279, meaning 28% longer diagonal (not 23%).
09-04-2018, 04:26 PM   #88
vZwicky's Avatar
Keen eye. Thanks, Mark Ransom. A typo it is. Correcting that now.
09-04-2018, 04:42 PM   #89
Somebody else said that?
09-04-2018, 06:03 PM   #90
vZwicky's Avatar
If I'm not mistaken, you did, surfar. I didn't want to weigh in until I crunched the numbers myself.
adapter, bodies, body, business, cameras, company, crop, ff, format, frame, frame mirrorless, fuji, gear, ilc, lens, lenses, lot, market, mf, mirrorless, mode, nikon, panasonic, pentax, post, release, sensor, systems, video
Some questions about buying sony full frame + adapters + pentax full frame lens jhlxxx Pentax Full Frame 8 06-14-2017 05:13 PM
Sony moves to #2 in US Full Frame Market/Sales Winder Non-Pentax Cameras: Canon, Nikon, etc. 93 04-22-2017 10:53 AM
From Full-Frame Sony... to Pentax... to Full-Frame Canon Mr_Canuck Non-Pentax Cameras: Canon, Nikon, etc. 42 01-21-2014 12:50 AM
Full frame or no full frame.... Deedee Pentax K-3 & K-3 II 14 10-08-2013 05:39 AM
Full Frame Full Frame vanchaz2002 Pentax DSLR Discussion 30 12-11-2008 07:09 AM
All times are GMT -7. The time now is 03:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
