Originally posted by UncleVanya Looking at the pictures - maybe 95mm at the smallest or perhaps 105mm?
Yes that has to be 95mm or larger. But I'm guessing 95mm.
What I'd like to see is a 3rd party release more novel lenses. Something like a 50-105 f/2 portrait lens and/or a 50-135 f/2.8 walkaround.
Something either with better performance than a 70-200 f/2.8 at the same size/weight OR similar performance at a reduced focal length range and size/weight.
I like having f/2.8 speed but don't need a lens as long as 200mm with it. On the other hand, a lens with faster aperture in a tighter focal range would be advantageous in some capacities too.
Eventually one of them is probably going to get around to making pancakes-like lenses now that the IS is in body (hoping the Canon body has IBIS too...). Drive motors can be made pretty small it seems as well.... for those of us not needing larger apertures for every day shooting and want to reduce weight.
Update: CR has specs on the lenses
Canon RF lens specifications - Canon Rumors | Canon Rumors Forum Quote: Canon RF 28-70mm f/2L USM - Lens composition: 13 groups 19 sheets
- Minimum focus distance: 39cm (15.35 inches)
- Filter diameter: 95mm
- Size: 103.8mm (4.08 inches) × 139.8mm (5.5 inches)
- Weight: 1430g (3.15lbs)
That's a beefy lens.
