11-01-2018, 02:14 AM   #1
Banned
ADAPTERS Antique manual Pentax objectives to Sony E-mount
Hello, like ... SMC PENTAX-M 1:2.8 28mm to SONY A7III ... given that I get this SONY and I have several PENTAX lenses because I would like to mount them on the SONY WITH AN ADAPTER .... but which: hmm ??? thanks and salu2 from Felipe
Last edited by BigMackCam; 11-01-2018 at 05:00 AM. Reason: Edited title and moved thread to non-Pentax forum
11-01-2018, 04:56 AM   #2
BigMackCam's Avatar
QuoteOriginally posted by Pentax K2 Quote
The best quality adapter is by Novoflex (it's not cheap, though!):
Adapterfinder Products - NOVOFLEX Präzisionstechnik GmbH
Fotodiox makes a significantly cheaper version that is quite similar, but undoubtedly not of the same quality. That said, this is the one I use on my A7 MkII and it's perfectly decent:
Fotodiox PKAF-SnyE Lens Mount Adapter - Pentax K AF: Amazon.co.uk: Camera & Photo
Whichever adapter you choose, make sure it has a ring for opening and closing the lens diaphragm
11-01-2018, 05:06 AM - 1 Like   #3
UncleVanya's Avatar
With the M series lens that's just a nice to have feature right? Like Ann A/M switch on m42, not required, but helpful. It is however required with any lens without an aperture ring.
I use Fotasy's DA/PK adapter for m43 use of lenses with and without aperture rings on my m43 gear. The adapter is solidly built and so far reliable. I suspect their Sony e mount version would work equally well.
Here's a link to the Amazon page for that adapter:
Fotasy Pro Pentax DA K Mount Lens to Sony E-Mount Camera Adapter (with Aperture Control) https://www.amazon.com/dp/B00FAAGG4O/ref=cm_sw_r_cp_apa_9VU2BbT2GHTCP?tag=pentaxforums-20&
11-01-2018, 05:14 AM   #4
Otis Memorial Pentaxian
Any experience with the ones that convert to autofocus? I remember a posting about that but can remember the adapter. they were quite expensive.
11-01-2018, 05:15 AM   #5
UncleVanya's Avatar
This plus the techart autofocus adapter is another option: FOTOMIX PK-L/M Mount Adapter for Pentax PK K Mount Lens to Leica M L/M M9 M8 M7 M6 M5 Camera Works with TECHART Auto Focus LM-EA 7 amazon.com : FOTOMIX PK-L/M Mount Adapter for Pentax PK K Mount Lens to Leica M L/M M9 M8 M7 M6 M5 Camera Works with TECHART Auto Focus LM-EA 7 : Camera & Photo?tag=pentaxforums-20&
11-01-2018, 05:16 AM   #6
UncleVanya's Avatar
This plus the techart autofocus adapter is another option: FOTOMIX PK-L/M Mount Adapter for Pentax PK K Mount Lens to Leica M L/M M9 M8 M7 M6 M5 Camera Works with TECHART Auto Focus LM-EA 7 https://www.amazon.com/dp/B01MTMVOGP/ref=cm_sw_r_cp_apa_c4U2BbGG4TC3S?tag=pentaxforums-20&
---------- Post added 11-01-18 at 08:36 AM ----------
11-01-2018, 05:40 AM   #7
BigMackCam's Avatar
Kind of, though I find the diaphragm open/close ring to be a little more beneficial than simply nice to have. It allows you to quickly open the diaphragm for accurate focusing, then close down to the selected aperture by just rotating that ring. It's just like using a preset manual lens, actually
QuoteOriginally posted by pearsaab Quote
I have the Techart LM-EA7 adapter. It's nicely made, but known to develop some play (or "wobble") in the lens mount over time, as it's only attached to the AF mechanism at its base. If you use it regularly, and with heavier lenses, it's (apparently) likely that the wobble will appear eventually. Also, if you're using longer focal length lenses - anything considerably longer than 50mm (e.g. 85mm, 135mm etc.), the LM-EA7 doesn't have enough back and forth movement in its mechanism to allow focusing from minimimum focus distance to infinity. Instead, you'd have to preset an approximate focus distance on the lens first. Lastly, it's fussy about which adapters will lock into place, because of the latch design. Anything other than Techart's own adapters can be a crap-shoot, unless you're happy to modify the adapter locking notch (I haven't tried the Fotomix adapter, so can't comment on that).
Although I was looking forward to owning the LM-EA7, and I'm not unhappy with it, I find I'm just not using it. Manual focusing is so quick, easy and accurate with the A7-series EVF anyway...
11-01-2018, 08:12 AM - 1 Like   #8
UncleVanya's Avatar
Mike - thanks that's very useful info you don't always get from the reviewers.
11-01-2018, 12:38 PM   #9
Banned
Hola,es este verdad.... Adapter Pentax K-Objektive an Sony E-Mount - NOVOFLEX Präzisionstechnik GmbH
Translation (added by moderator):
Hello, it is this truth.... Adapter Pentax K-Objektive an Sony E-Mount - NOVOFLEX Präzisionstechnik GmbH
Last edited by BigMackCam; 11-01-2018 at 12:43 PM. Reason: Translation added - please always post in English (thank you!)
11-01-2018, 12:43 PM   #10
BigMackCam's Avatar
Yes, that's it!
11-01-2018, 04:07 PM - 1 Like   #11
jlstrawman's Avatar
Yes, that's it!
+1 on the Novoflex. The build quality is substantial. I love mine. Several of my lens that couldn't be focused
to infinity, with cheap adapters, do so with the Novoflex. For me, the extra cost is worth it.
11-03-2018, 08:10 AM   #12
I’ve just started adapting older lenses to my A7iii. Starting with the smc-m 50/1.4 and super tak 50/1.4, and now taking on some legacy Zeiss glass too. I’ve not played with any AF adapted lenses, but even the Fotasy and Fotodiox branded adapters work fine for MF glass.
11-05-2018, 06:52 AM   #13
Thanks Mike!!!
adapter, auto, camera, m5, m6, m8, m9, pentax, sony, tripod
How are you doing with your 2018 Photography objectives? ChristianRock General Photography 55 06-30-2018 03:05 PM
Nature Antique Feeder. DW58 Post Your Photos! 3 03-29-2018 07:59 AM
Problem with "antique" Pentax lens Bob 256 Pentax SLR Lens Discussion 7 01-09-2018 12:46 PM
Antique Bazaar with pentax Q10 lens 02 volkan Pentax Mirrorless Cameras 4 04-09-2017 01:58 PM
All times are GMT -7. The time now is 10:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
