11-03-2019, 03:18 PM   #1
Retrieving usable film from EOS500
Hi, Iíve got hold of an old EOS500 with a film in it thatís only used a few frames.
Seeing itís a good film, Iíd like to use the rest in my ME Super.
Does anyone know if the automatic rewind on the EOS500 will leave a lead/tail on the film, or wind it right back into canister? Iím probably safest just opening the back, manually removing the film and cutting a new lead right?
11-03-2019, 03:39 PM - 1 Like   #2
If you have a local lab, write down what frame youíre on and rewind it. The lab can pull the leader out again.
Then, put it in the Pentax, advance a frame or two past where it stopped before by shooting in manual mode (1/1000 s and f22) with the lens cap on, and go on your merry way.
Alternatively, you can buy your own leader retriever and do it yourself, but it needs practice to use one properly...
Or, your suggestion also works. You just wonít get to see the prior ownerís photos
-Eric
11-03-2019, 03:56 PM   #3
Since you're going to remove the film canister anyway, why not do that in a dark room or changing bag and manually rewind the film into the canister, feeling the amount remaining until you have it to a point where the lights can be turned on? It shouldn't be too much film to rewind being there are only a few frames exposed and you can turn the canister film shaft until a tab remains. Then you can load it in your Pentax and advance it with the lens capped until you feel you're past the exposed frames and you're in business.
11-03-2019, 03:59 PM   #4
Thanks Eric, had no idea a leader retriever was a thing. This time I think I’ll just bin the spent frames - not curious enough
But I’ll add a retriever to the list of things to buy ����
---------- Post added 3rd Nov 2019 at 16:04 ----------
QuoteOriginally posted by Bob 256 Quote
... why not do that in a dark room or changing bag and manually rewind the film into the canister ...
Ah thatís also a good idea! Clearly didnít give this much thought did I!?
film, idea, retriever
X-rayed film is it still usable? Zooland Film Processing, Scanning, and Darkroom 15 10-06-2019 02:47 PM
Retrieving Hidden EXIF data DominicVII Digital Processing, Software, and Printing 4 05-02-2014 04:52 AM
Any suggestions for a lens around 20mm usable on film/digital? RXrenesis8 Pentax SLR Lens Discussion 34 04-05-2012 05:15 PM
Need Help Retrieving Photos.... Gsmp Troubleshooting and Beginner Help 6 03-02-2011 08:27 AM
re-usable film cartridge maximum capacity? Gooshin Pentax Film SLR Discussion 20 03-03-2009 02:16 PM
All times are GMT -7. The time now is 01:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
