As a Leicaphile I will do my best to address some of the criticisms and questions that have been raised:
Originally posted by tuco A red filter can cost you up to 3 stops of ISO speed
Not a problem with the admittedly expensive Summilux class lenses, but even in bright daylight a Summicron is perfectly capable of handling a 3 stop loss with aplomb. The real boon with a rangefinder is that you view is unaffected by the filter like it would be on an SLR. But that also makes using a polariser filter somewhat
problematic for obvious reasons.
Originally posted by Marcel K Maybe stupid question: if you put your color dslr camera on B&W mode, would you have more pixels at your disposal, because you don’t need red-blue-green?
There is still a lot of interpolation going on. The green channel contains 50% of the lumunance detail with the remaining 50% being divided equally to red/blue channel data. The channel with the most pixels wins when it comes to luminance.
Originally posted by biz-engineer Monochrome sensor makes more sense on a medium format camera
Thankfully Phase one make the Achromatic+ line of digital backs, also I recall Hasselblad also have a Monochrome MFDB available. I have said a Monochrome 645Z would be
wonderful and would give Pentax another market niche to exploit as Phase and Hassy Monochrome MFDB are
very expensive.
Originally posted by gofour3 Buy a used P6x7 or 67 or 67II
Prepare for itemized rebuttal: [1]A Leica M rangefinder is considerably lighter than a Pentax 67 [2] you get more frames on a roll of film and developing can be done
conveniently Via a service or by yourself [3] you never need to use mirror lock up, [4]you never need to worry about mirror slap that sounds like someone dropping a heavy coin in a tin bucket.[5] Lens filter sizes are
considerably smaller.
Originally posted by photoptimist 2) I don't like the labelled dialed UI of the Leica. The e-dial design of the K-1 is better for working with the full range of exposure settings and for resetting the dials to an auto value as needed (M+green button rules!).
3) I prefer the K-1 body. The Leica body feels like a hold-over from the film era rather than something designed for the human hand.
4) The cost!!!!!!
Ergonomic concerns are different for everyone, and are very relative and subjective things. There are some things I dislike about Leica's UI design, when it comes to Leica the camera is more about the hardware rather than the software. Not to say they don't put some effort in but as always Leica's forte has been design and engineering. Not much can be done about cost though, I do admit that financially, they do ask a lot for such a niche product. Leica is a brand that has been around a very long time, even longer than Pentax and just as long as Schneider & Zeiss. Zeiss products command high prices too, and Schneider optics aren't cheap either. Leica isn't really that expensive when you take a look at high end European optics and photographic equipment.
Originally posted by lesmore49 there's nothing quite like a Leica rangefinder.
No, there simply isn't. But there are plenty of other excellent options if Leica doesn't suit: The Konica Hexar RF is in many ways superior to the Leica M7. The Nikon SP is also an excellent choice, Bessa rangefinders are also very good (though reliability is a continuing issue)
Originally posted by noelpolar I've been attracted to the Leica world recently
All it takes is to buy one camera with the
red dot and down the rabbit hole you will go.
Originally posted by stevebrot You bring up an interesting subject. What is the spectral response of cameras like the M10 Monochrome and how is it imposed?
The monochrom is still equipped with a hot mirror like most DSLRs are, however when converted* to hyperspectral imaging the output in UV and IR is quite breathtaking, You can still use the camera for UV and IR unconverted, but shutter speeds are not in the easily hand holdable range. I do have some examples I'll have to dig up from my archive though my monochrom is unmodified for UV or IR.
Originally posted by johnha I bought a beaten up M4 and Voigtlander 40/1.4 a couple of years ago
Excellent choice, the Leica M4 and M5 are shunned among Leica devotees, the upshot of this is that the price for those models are consistently lower I cannot fathom the why M3,M6,M7 are
Venerated but the M4 and M5 are consistently priced lower than the more revered models, Leicaphiles treat the M4 and M5 as if they do not exist.
*Leica does ( or did) offer a service to remove the hot mirror and replace it with glass of equal thickness and optical qualities, at a cost.
