No regrets with this Z5 after a month. I could have used higher frame rate once but not that big of a deal, still got the shots I wanted. I’m finding with the EVF that I pretty much don’t leave M mode at all compared with DSLR. You don’t have to worry about accidentally having settings off as you’ll instantly know through the viewfinder if exposure isn’t what you want. Also zero chimping or reviewing shots now, I know I got what I wanted the first time for exposure. The 24-200 has been really good for travel. I’m also glad it’s 2 SD cards and not a compact flash. I know they’re faster but that would have meant more costs for the card and for a reader that works with my Ipad, then a reader that worked for my laptop, so 2x of those added to the cost.
If you really need the burst rate I’d go for the Z6 or ii. But the image quality on the Z5 is great and I’m not wishing I had the BSI sensor at all. Really it just comes down to do you need the high frame rate. Autofocus has been great. It’s the same as the Z6 there. Worth consideration too is the Z5 FSI sensor has slightly better dynamic range than the BSI sensor in the 6, which is slightly better at really high ISO.
I also don’t miss the top screen at all. Didn’t on the OMD so I already knew that. Settings are on the back or in the EVF so it’s just triple redundant to have them on top anyway. Plus IMO the dial is better positioned on the Z5 for modes and it has no lock button which I prefer. Lock button just makes it harder to switch with one hand.
A couple of shots around great salt lake while I’m out here for work.
From the 24-200 and 2mp from snapbridge. Which is what I typically use for sharing as no need for large files if your texting them to relatives or for here. They can transfer in realtime as you shoot or later, and it’s fast. You can also download the full size images if you want but I just pull the SD and use a reader for RAW if I want to really get into editing one. Edits were don’t on my iphone in it’s native editor within a few minutes.
