Originally posted by UncleVanya Can you clarify where this is shown? I'm confused since the Pentax K-1 essentially (both models) has nearly perfect ISO accuracy. The Nikon overstates ISO. I struggle to understand how an ISO 46 (Z7ii set to 64) shot would have the same exposure as an ISO 95 (K-1ii set to 100) shot. As for highlight protection - shooting at ISO 70 and exposing for ISO 100 will give more headroom as it underexposes a bit.
The iso standard relates to the out going image lightness and not how the camera uses the sensor, and if you look a the the standard it specifically states that it is not related to the raw file. If you look at how Nikon uses it sensors and how much headroom is contain within the raw file.
Depending on how Pentax uses the sensor you have to remember that sensors have no iso setting, setting the iso tell the camera how and for some cameras program how the sensor is to be used. The iso setting for the Z7II at iso 64 is the iso setting for iso 64 as this relates to how the final image lightness will appear within a color space and not how the sensor is operated, Now if you are using DXO measured iso this has nothing to do with iso and the iso standard that governs what the iso standard governs, The measurement at DXI is of how much headroom is contained within the raw file so if we look at iso 64 it can accept an exposure that is equal to iso 46. And to state this again the measured iso at DXO has nothing to do with the iso standard.
As for just shooting at iso 70 and using iso 100 giving you more headroom it really depends on how the manufacture utilizes the sensor and it depends on how much headroom they have decided for. The only camera from pentax that i know of that using an iso lower than 100 was the K5 series cameras that gave the user a lower iso setting while retaining the same headroom that was not simply an expanded iso range.
A person can also gauge how much high light headroom raw file contains by looking at the baseline exposure tag found within the raw file that tells the converter where to place the 0 point so a positive the camera has more headroom and a negative less headroom
https://photographylife.com/where-are-my-mid-tones-baseline-exposure-compens...0make%2Fmodel.
For most pentax cameras we usually see around BLE of -0.5 where as Nikon usually around +0.35
Now if well look at images taken under controlled lighting the Z7 is using the same exposure at iso 64 as pentax at iso 100
Nikon Z7 Review - Thumbnails Pentax K-1 II Review - Thumbnails
Now if we look at the headroom
Many times when lowering the iso setting all that is happening is you are calibrating the meter for a lower iso and changing the BLE in the raw tag telling the raw converter how to process the image
going from iso 64 down to iso 31 did not change how much light you can store and did not change , there would be no different is shooting the iso 64 shot at with as large exposure as iso 31 ( or ETTR )and adjusting the lightness of the final image in the converters as this is what the tag in the raw data is telling the converter to do anyways.
Also setting the camera to iso 31 and shooting it with an exposure = to iso 64 change how much headroom the camera has
But with how Nikon has decided to use the sensor they are able to increase the size of the exposure to collect more light
---------- Post added 09-01-2021 at 01:50 PM ----------
Originally posted by Rondec I wouldn't think they are that different if you shoot RAW. Looking at Photons to Photos graph of DR
You have to be careful as to how you are interpret PTP graphs as they are based on the iso setting and not how the sensor is being saturated (EETR) and as shown for the same exposure you have very similar PDR but if you use nikon as (ETTR) there is a difference to the PDR
---------- Post added 09-01-2021 at 01:56 PM ----------
Originally posted by normhead Exactly, two cameras with virtually the same DR have virtually the same headroom.
Headroom has nothing to do with the DR, the headroom is determined by manufacture as to how they want to use the storage within the raw file
Originally posted by normhead If two cameras shoot the same settings at 64 ISO and 100 ISO then the ISO or the two cameras are functionally the same.
Far from it. take the Z7 at iso 64 has the same DR but with over 1.3 stops of headroom over the K1 so no.
---------- Post added 09-01-2021 at 01:58 PM ----------
Originally posted by UncleVanya If you check the DXOMARK iso tests they have a standard and show how closely cameras adhere to it.
That has nothing to do with the standard, all they are showing is how much headroom in the raw file is there
The iso standard determines how light or dark the image will be within a color space for a given exposure
For pentax this is usually around 1/3 stop over but for Nikon its around 1/3stop under, and again this has nothing to do with raw and the DXO measured iso as this is for normalizing the cameras performance based on the saturation of the sensor.
We can have 2 different camera manufactures that use the same sensor with very different head rooms as to why raw converters need to use very different baseline exposure values to correctly process the image.
But both cameras will render the image very closely to the iso standard, which is why the raw converter needs the BLE value when editing a raw file
