Originally posted by Hey Elwood I was shoting with a flashgun on SV mode with the ISO set to 200. I was using AF as well with continueous focusing.
Not to mention the fact that when I talked to him about his camera he showed me how his attached Nikon flashgun would extend to 85 mm on TTL mode. I know for a fact Pentax will only extend the flash gun out to 58 mm on TTL...trust me...I tested it on a 540. When I called Pentax for assistance on that issue a few months ago I was told no digital SLR would extend a flashgun out further then 58 mm.
I just proved that was not true.
Hmmm.. how to say this and at the same time, not offend?
About the flash extending to 85 mmm.... well, the pentax rep is RIGHT. Your 540 will extend up to 58 mm if set to DIGITAL. If you set it to 35 mm, then it will show 85 mm. Extension is the same (and angle of coverage too). Pentax is just being more informative with the 540 and lets you know what the real angle of coverage is depending on shooting format.
About your pictures compared to the ones from "the other guy", I have to say there is one BIG difference. The background!. In all his pictures, except probably the last one, none of his backgrounds are as bright as yours, meaning this, that he did not had to blow the backgrounds to properly expose the main subjects.
About the focus issue, well my friend, that is a matter of practice and knowing your gear. I personally thing choosing continous af with this type of pictures is an error. Also, if you chose continous af PLUS auto af sensor, then you are asking for the same results you got.
Stop blaming the instrument about what is supposed to be managed by the photographer. It is like claiming someone is a better musician because he plays a Steinway full size concert piano and not a small stand church piano. If you are a good musician, you can make any instrument sound good, but if you suck at it, it won't help to have the Berlin Philarmonica with von Karajan directing your concert...
