Originally posted by georgweb Hi guys,
I'd like to know from your experience if you could rate the following cameras only regarding low light performance. Let's be more specific, I'd appreciate 'real world' experience with those cams, dark indoor shots, stage shots, artificial light.
The easiest is to talk ISO I guess (in the sense of keeping the DR and the pic not totally falling apart). Obviously my yardstick is the first camera.
Pentax K100D (my current DSLR) - acceptable ISO: 800
Canon 5D 'classic': 1600 ? (the most tempting upgrade for me)
Nikon D700: 6400 ?
Sony A850: 800 ?
Pentax K-X /Sony A500 (presumably same sensor): 1600 ?
As for many other people the low light perf. is crucial to me and I just can't tell if it would be worth upgrading for two stops. I am using manual f/1.2 - f/2 lenses in those situations whenever possible so I can't do much better lenswise with my current camera.
Any thoughts appreciated,Georg (the other)
Georg,
From what I've used;
The K10D can get good high ISO results, but you need to expose to the right. Anytime you need to push the exposure, the noise gets bad. This I find is an issue with the K10D because the camera tends to underexpose 2/3 to 1 stop. So you really need to be aware of your histogram.
The 5D shots I saw from my co-workers camera at ISO 1000 looked better then my K10D shots at ISO 400. Granted, I had a number of shots underexposed, because I forgot to watch the histogram.... I really need to learn not to trust the matrix metering on the K10D.
The D200 has a much better matrix meter then the K10D, producing far more correctly exposed shots over the K10D. But, When the K10D is correctly exposed, it has far better high ISO images then the D200. The D200 has a faint "ripple" texture to its high ISO noise. It can be seen from about ISO 600 and up.
When I had a K100D, I took very few high ISO shots. But the few that I did take had a very film like grain pattern to them. Usually I would convert the shot to B/W.
I was looking at the high ISO images from the dcreviews "compaire-o-meter" from the A850 and the K-7. I found that downsizing the A850 images to the same res as the K-7 resulted in a better image then the K-7. It has made me reconsider the A850 as a camera. Has anyone else noticed that downsizing can improve image noise? This is an idea that is new to me.
