Ok, after a serious play with the EOS 7D and a good read of the manual, here are my likes, dislikes and verdicts. Please remember that I'm coming from a K20D so my feelings will be based on switching from a body that's over 2 years old now. If you're a Canon 50D owner, or a Pentax K-7 user, you may feel differently about it. So here goes:
Good points / Likes
- The Autofocus. It's not great, it's absolutely brilliant. Very fast, very accurate, impressive low light performance to go with it. Better still, the ability to fully customise from single, to assisted-single, to cluster, to "all 19 AF points" to suit your needs is tremendous. You can also fully customise the AF sensitivity for tracking to prevent the focus being thrown by an object getting in the way (such as another player in a football game). The AF drive priorities can be set too so that the AF takes priority over the drive rate, and vice versa. Auto rotation of the AF points when moving from landscape to portrait is an excellent touch.
- The Autofocus. Did I mention the autofocus?
- Canon USM is clearly superior to SDM (comparing my USM lens to my 17-70 SDM).
- The 15-85mm USM is a
very sharp lens and makes the most of the 18 MP.
- Having 18 megapixels to play with is great, but there is a caveat (see below).
- Frame rate. I don't need to use the full 8 fps just yet, but it's good to have under your finger when you need it.
- ISO performance. ISO 3200 is no problem for the 7D and noise is very minimal after some Noise Ninja attention. ISO 6400 starts to tail off.
- Weather sealed. Don't believe me?
Look here. One point that kept me away from Canikon was somewhat wishy-washy stance on weather sealing on their semi-pro bodies. The 7D is the first affordable weather sealed unit - this was very important to me moving from the rugged K20D, I didn't want to give up the weather sealing.
- 100% viewfinder. What you see is what you get.
- Customiseable viewfinder. Don't like those black boxes for autofocus points? Turn the unused ones off in the menu! Don't like the grid? Turn that off too!
- The rear screen is excellent.
- All the buttons are in the right place. Metering, white balance, AF drive and ISO are all under my index finger.
- The HD movie modes are excellent and video quality is just supreme. I didn't think I'd care about video, but being able to shoot small videos to go with shots has been great fun. I've become an uncle recently, and making small videos of my nieces has been great fun and in great quality too.
- Long exposure noise reduction can be switched off
completely, no more waiting around when I shoot 2 minute exposures.
- Build quality. It's rock solid, everything feels substantial and very good quality.
- Auto white balance and the metering system works without giving it a thought, even under tungsten - good job Canon.
- A large range of pro spec telephoto lenses to choose from plus excellent rental opportunities.
Bad points / dislikes
- The build quality comes at a price: it's big and it's heavy. If you're a fan of D90 / K-7 sized & weighted cameras, stop reading now and don't buy a 7D. On the plus side, it fits my hand perfectly and I find it very comfortable to use. The weight doesn't bother me however it may bother those that want to travel lightweight with a bunch of Pentax ltds.
- Maybe not a bad point, but it comes with the territory: this is a pretty complex camera and you need to invest a lot of time on getting to grips with it. A week later and I'm still reading the manual, and still running a few tests. It doesn't matter how much you think you know about photography, this is a serious camera for serious photographers - stay away if you just aim to take some holiday snaps or the odd picture of a flower. There is a lot of moaning and whining over on dpreview.com of people who are disappointed with the 7D performance, but on reading their posts it's pretty clear they just don't know how to use it.
- no TAv mode.... however there is an auto-ISO mode under the manual setting. Dial in your aperture, shutter speed, set the ISO to 'A' and it'll work the same way as TAv. My only problem is that you can't set + or - EV using auto ISO this way, I hope Canon address this in a firmware update.
- Mirror lockup. This is a minor niggle and could be construed as positive or negative, perhaps I'm stuck in my Pentax ways. You need to enable mirror lockup through the menu (disabled by default). This isn't that big a deal, but I was just used to be able to set it to a 2 second timer and let it do it automatically. It would have been nice to have the ability to enable, disable and 'when using self timer'.
- Pentaxians are bound to miss the rear eDial under the right thumb, but you very quickly adjust and I now
prefer to have nothing cluttering up my thumb area. I simply move my thumb to the left and the eDial on the back is in perfect reach. YMMV.
- I'm not convinced 18 MP was the right thing to do, I'd have preferred 12 MP and vastly improved ISO 6400 noise. Infact, I think the Pentax KX at ISO 6400 is little bit better than the 7D based on what I've seen over at Imaging Resource.
That said, APS-C doesn't do a great job of ISO 6400.
- No lends hood with the 15-85mm lens package?! Come on....
- No tripod collar with the 70-200mm f/4 L? Come on.... (plus it's about £60! - cheap imitation from ebay will do me)
- No HDMI lead supplied.
