Originally posted by tokyoscape I bet people like that won't survive as a pro for so long if they only do easy things. The other guy I can not mention here also pretty much the same. They are not in the industry for a few years but +2 decades. They were using another well known brand earlier in their career. And both find no performance problem after switch to a smaller player like Olympus. That's why I don't think OP will find problems doing wildlife using an Olympus camera.
These days you can survive as a pro with pretty much any gear as long as you have great marketing skills. I have quite a few examples around me, not only in photography.
When wildlife is mentioned, I associate the word wildlife with action while many others are talking about static subjects. It's my fault because I should have mentioned this aspect. We have a popular pro wildlife and landscape photographer in Romania who was a Nikon ambassador until he had an argue with Nikon Romania and he switched brands to Olympus because Olympus was the first (maybe the only one also) to give him gear to test it. He has great images taken with Olympus, but a lot of people realized that Nikon images were better, especially in terms of subject isolation. This doesn't mean that Olympus doesn't produce great images as long as you use best Olympus lenses. The guy I'm talking about is using E-M1X and 300mm f4 lens for wildlife.
Speaking of weight, let me give you just one example for wildlife:
1. Olympus E-M1 Mark III with Olympus 300mm f4 weights 2,05kg. If you add a grip to E-M1 for better handling, the weight will be around 2,3kg. The cost of this combo at B&H is 4550$ without battery grip.
2. Nikon D500 with 500mm f5.6 weights 2,32kg. The cost of this combo at B&H is 5096$.
Going with Oly you'll save 270g and 546$. If you add a grip to E-M1 Mark III the weight and price advantage is gone. Given the ISO performance between m4/3 and APS-C, I say that in terms of image quality at high ISO will be pretty similar the images in terms of noise due to the difference in terms of aperture between lenses, but handling, subject separation and af performance of Nikon gear will be superior to Oly.
I would actually look also at the new Fuji X-T4 (new 26mp APS-C sensor, 5 stops of IBIS, new processor, 15fps with mechanical shutter or 20fps with electronic shutter) with Fujifilm 100-400mm lens for wildlife over Olympus...
That's why I insist that people should try and rent/borrow before investing in a new system.
---------- Post added 03-02-20 at 08:01 AM ----------
Originally posted by larryaustin3 While the D500 is a great performer as you said, it's a beast compared to the Olympus in size and weight.
If we talk about wildlife, take a look at the above comparison I did and you'll see that the weight difference between the Nikon D500 with 500mm f5.6 lens and E-M1 Mark III with 300mm f4 lens is only 270g.
Oly is quite unbalanced without grip with the 300mm f4 lens and therefore the size and weight is gone if you add a battery grip for Oly. For wildlife D500 with 500mm f5.6 would be my choice any time of the day over Olympus.
