Originally posted by Angelic Layer I would also look at included lens, I prefer Jupiter which is a Sonnar design to Industar, though the Industar is more compact.
I personally prefer Zorki 4K with lever advanced, not much personal experience with Zorki 6 but this is what I read.:
Fed is more compact but generally came with Industar, a Tessar type design instead of Jupiter.
You might also want to look at Kiev 4AM if you are willing to spend a but more as some of these came with the even superior Helios lens, but make sure it is working of course, the shutter ribbon is their weak point, most consider the Kiev to be a finer camera than either Zorki or Fed.
Oh my, more confusion!
I think the FED-2 (D type) seems to be a nice combination of ease of use, general ability and aesthetics.
I don't think the seller has a Zorki 4K, but definitely has a Zorki 4 and Zorki 6. The 6 looks nice but seems to be inferior to the 4K.
The seller also doesn't have a Kiev 4A, but instead a 4M with the Helios 103 lens, but unfortunately that doesn't look in as good a condition and is also not as pleasing on the eye!
I'll have to sleep on this one (again) I think!
I can always pick up a Jupiter after the fact - actually, given I use mirrorless, all I need to do is acquire a M39 adapter and I can try out a few lenses on both film and digital.
