03-27-2010, 01:59 PM   #1
Nikon high ISO noise reduction?
So I picked up a D300s a little while back and for the most part have been leaving high ISO noise reduction at the "normal" setting. For those also shooting Nikon, do you find that "norm" NR smudges too many details or is it the optimal setting? And I do often shoot RAW if that helps. Thanks.
03-27-2010, 09:47 PM   #2
icywarm's Avatar
maybe try.... www.canikonforum.com
03-29-2010, 10:32 PM   #3
Thanks. So far NR set at "normal" seems to be giving good results. On my K20D I always leave NR off so it's just a matter of getting used to the difference.
03-30-2010, 01:00 PM   #4
edl
I'm not sure about the D300s sensor, but I leave NR off on my D700. JPEG's look fine straight out of the camera.
I believe the NR settings don't make a huge difference if you shoot RAW, but I could be wrong.
03-30-2010, 02:09 PM   #5
edl, I didn't consider that NR would look that different applied to RAW vs. JPEG files--thanks.
iso, iso noise, nikon, noise
K-x high-ISO noise reduction: use it or do it in PP instead? richardm Troubleshooting and Beginner Help 5 10-28-2010 08:45 AM
High ISO - black and white - no noise reduction look kxuser Photographic Technique 43 04-08-2010 06:59 AM
What do you guys use for high iso noise reduction? rustynail925 Digital Processing, Software, and Printing 38 12-04-2009 01:28 AM
High ISO Noise Reduction on K20D - Does it do anything in RAW? ksignorini Pentax DSLR Discussion 4 07-23-2008 03:53 AM
K20D - High ISO Noise Reduction - How? How much? When? ksignorini Pentax DSLR Discussion 4 04-13-2008 01:14 PM
All times are GMT -7. The time now is 04:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
