So my Dad found an old Hanimex TX-60 manual flash. I popped it on my MX and shot a role of cheap stuff just guessing exposure, since i have NO idea how to set the thing properly.
I developed the role, and all the pictures were severely underexposed, but i could still recover some image.
I had taken one shot of myself in my washroom mirror for technical purposes, and what do you know...the flash isn't even lit up (instead it's just giving off a slight glow like it does right after it fires).
I got my camera, opened the back door and put my eye where the film would be, i fired a shot up against a wall at 1/60th...i should have seen a bright circle for the split second the shutter opened, but instead i just saw darkness.
After fiddling around with the camera and flash for a bit, i plugged the unit into the second, lower port, and tried my little experiment again. Opened opened the back door and put my eye behind the shutter...fired a shot at 1/60th and BAM a bright white light pierced through the lens into my eye.
A tried a few more times trying the first flash port and i can confirm that only the second port is actually syncing the flash to the shutter. I know now to only use the second port but still...why is the first port pre-maturely firing the flash?
Someone explain?
