Originally posted by spores Shutter Speed. Inside. IF I set the film speed to 100 (rather than 400 which is the type of film loaded) I can set the shutter speed to 1000 and the needle is in the middle (changing the aperture while the meter is on or off does not change the position of the metering needle).
Outside. IF I set the film speed to 100 (rather than 400 which is the type of film loaded) and set the shutter to 250... changing the diaphragm ring has no effect - meter shows way overexposed.
Thanks for the help so far... does any one have a link for cleaning the camera's contacts?
Question: when you turn on the meter and then set the aperture from 1.8 to 16, does the lens get noticeably darker? If it does, the stop down mechanism associated with the meter is working correctly.
If it does not, either the auto mechanism on the lens is faulty or the "kicker" in the body is not engaging the pin.
In the case that the lens doers not get noticeably darker moving from open to closed aperture, try setting the lens to Manual instead of auto and see if aperture effects a change. Use a reasonable shutter speed of 60 to 250 while pointing at a light bulb. On my Spotty, 55 f/1.8 at ASA 400, pointing at a lightbulb on an lamp with a shade reads good exposure at 125th shutter speed, f/2.8. Your results may vary.
Make sure to turn the meter on. See if you can get the needle to go up and down with the lens in manual mode. Putting it in manual will cause the aperture to close no matter what and you can see if at least the meter is working. Calibration is another thing however.
Séamuis is right of course. However, it does not hurt to do a little diagnosis.
For me
woof!
