12-04-2006, 01:52 AM   #1
My MZ-50
Got my MZ-50 (USA= ZX-5) today. I have to say i am pleasantly surprised. Initially I got a P30, and I saw the MZ-50 for thirty bucks more and thought "hmmm...autofocus, continuous shot, body controlled PASM" but was initially hestitant that it wont work with non A lenses. Well, the verdict is that although it wont work with my SMC M 50mm and Zenitar , it *did* work with my M42 screw mount lenses in Av (and M) mode, contrary to internet literature!! I Confirmed this with my K100D on spot metering, Av, identical ISO - the two cameras yielded identical Shutter speeds, and turning the aperture ring does indeed change the shutter speed correspondingly
Next thing is to go out and do a test roll. If all goes well I think my P30 will be returned to the good old ebay pool w/ my M lenses to raise funds for a 50mm AF 1.7 =). but on the other hand, it does make a neat backup body with some of the MF primes
12-05-2006, 03:42 AM   #2
Not too sure if you have made a typo but:
MZ-50 = ZX-50
MZ-5 = ZX-5
cheers
Kenny
12-06-2006, 07:33 AM   #3
Nesster's Avatar
Thanks for the info - I have the ZX-50 and I've been wondering about just that, it's good news about the M42 mount, good news indeed! What adaptor are you using?
In case you're wondering (probably not) the body works great with a Lensbaby
On further thought - when you change aperture, the lens stops down... the viewfinder gets darker? or vice versa, when opening the aperture?
That is, the M42 lens works in 'stop down' mode? Ie. if you want to focus wide open, you'd first set the aperture to wide open, and then stop down to the desired taking aperture. The camera will meter correctly based on that.
Or is there something else going on....
12-06-2006, 09:15 PM   #4
hiya Nesster,
I'm just using one of those M42 - K ring adapters from ebay, ie no electrical contacts. And the lenses I'm using are stop down metering ones (ie viewfinder goes dark), tested with takumar 28mm, on Aperture priority mode.
I think i have to wait for my first roll to get processed and post it up b4 im sure it works
03-09-2007, 08:43 AM   #5
I have a MZ-50 too! I love her!!!
See more in:
https://www.pentaxforums.com/forums/pentax-film-slr-discussion/715-processing...html#post34595
Hugs from Brazil!
Themeron
50mm, av, body, lenses, mz-50, p30, shutter
All times are GMT -7. The time now is 04:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
