First things first...Before even trying the shutter or anything else:
- Check the battery compartment for any evidence of corrosion. Clean is good.
- Check the condition of the door seals and mirror bumper foam. If the seals and/or bumper are even slightly sticky or gummy, they will need to be replaced. This is particularly true for the mirror bumper. The mirror strikes the bumper when it swings up to make the exposure and flips back down afterward. Sticky material may then be flung onto the surface of the focus screen where it will be very difficult to remove. You can replace the seals/foam yourself (see interslice on eBay for kits) or simply have the camera CLA'd.
If the both of the above look good:
- Run through the operating instructions in the camera manual. A copy of your camera manual may be found HERE (donation appreciated).
- Buy some film and enjoy the camera!
You can still get color print film at many drug and variety stores (Walgreen, Target, etc.) and many also still provide processing for color print film. As for processing...I use my local pro lab for C-41 color print film since they charge the same as Costco and provide somewhat better results. For B&W film, unless you have a real camera store nearby your best source is probably online. I buy from
freestylephoto.biz or from
digitaltruth.com. I do my own B&W processing since it is much cheaper than paying for the lab to do it.
