Originally posted by wehavenowaves! ... my skys are totally blown out and there is not much contrast in many of the shots... what variables do I need to consider and improve upon next roll? ... please help a newbie!!!! THANKS!
You don't mention if you're new to film, new to black and white, or to photography overall, etc., but I'm inferring new to B&W film, since you're calling yourself a newbie in a post in the Film SLR section! The contrast in your pix doesn't look that bad, and as to the "blown-out" sky, consider this: seeing life in color, you're accustomed to the sky contrasting greatly with adjacent subjects: blue sky vs. green trees or grass, blue sky vs. white sand, etc. But as to overall luminance, the (daytime) sky is
very bright, which in B&W will naturally get you to the tones you're calling "blown out." Assuming you came from digital, you might want to do a roll of B&W film in the new MX and duplicate each pic with your DSLR in B&W mode (to save time; need not worry about shoot color RAW and desaturate later). Ideally, do the DSLR shots in centre-weighted metering, then in whatever fancy matrix mode you're most accustomed to. Compare the DSLR B&W shots to the film ones, and you may find that they're actually pretty similar,
i.e., the problem is not with the MX but with blue skies in B&W generally. Often, to make the daytime sky in B&W as dark (or as much in contrast to foreground subjects) as a blue sky "feels" in color, you'll need to load on a yellow or orange filter (as mentioned above) and a polariser, and/or burn in the sky when printing.
Hope this helps.
--Dave
