02-24-2012, 10:22 PM   #1
Will a 46mm polarizer vignette on the 43mm?
Hi,
I'm just getting stated in film photography with an MX and my 43mm. What a combo!
I have a 46mm B+W warming polarizing filter that I'd like to use occasionally. I got an step down ring and looking through the viewfinder I don't notice any obvious vignetting, but it's already darkened by the filter so I can't be totally sure.
I don't mind a little trial and error, but I know there are a lot of experts here who might be able to clue me in.
Any ideas?
Thanks!
Chris
02-24-2012, 10:39 PM   #2
Lowell Goudge's Avatar
Since you already have all the parts do 2 test shots on a paved road or other uniform surface and look for differences with and without
02-25-2012, 03:32 AM   #3
foto guy's Avatar
I don't know for syre, but I suspect that there will be at least a little vignetting when shooting at maximum aperture.
Follow Lowell's suggestion and make sure to shoot at max aperture and work your way down to 5.6 or so. And take notes--otherwise you won't know what you can get away with.
02-25-2012, 04:07 AM   #4
wlachan's Avatar
Probably not I guess since the front element is rather small.
02-25-2012, 06:35 AM   #5
Probably not as 43 mm is a full frame lens, on aps-c this image circle is reduced and the vignetting induced by the polariser should be hidden; it may be visible on a full frame SLR, but this is another debate
02-25-2012, 10:01 AM   #6
As I recall the MX finder covers about 95% of the actual film frame, so you can get vignetting on film that you don't see in the finder. This happened to me a few years back using the SMC 24mm lens with a filter and generic WA hood. All looked great in the finder, but I had to crop out the black corners on every shot. Since then I've found the Pentax rectangular hood made for the 24, and it eliminates the problem.
Most SLR finders don't show quite the entire frame.
02-25-2012, 11:32 AM   #7
Otis Memorial Pentaxian
Do the test shots with a roll of cheap film. Any evenly-lit bland subject will do (blank wall, cloudy sky, etc.) Shoot at f/5.6 and narrower. Vignette from a hood or filter ring is more apparent as you stop down and is often not particularly visible in the viewfinder.
02-25-2012, 02:25 PM   #8
Thanks for everyone's advice
Looks like I'll have to try it to find out!
At the moment I have a nice roll of film in there, so I probably won't be taking too many test shots. Still, I'll snap at least a couple frames with the polarizer in place to see what happens.
I'll report back when I know how it turns out in case anyone is interested.
Thanks again,
Chris
02-25-2012, 02:34 PM   #9
Unfortunately, experimentation is often the only solution in the matter of hoods and filters and vignette. I have a short hood that I use with my Jupiter-12 25/2.8 in LTM mount. It works great even with a filter mounted between the hood and the lens. I have also have a Jupiter-12 in Kiev/Contax mount and am uncertain whether the hood/filter combination will vignette, despite the similarities between the two lenses. The roll currently in the camera will tell!
02-25-2012, 03:54 PM   #10
SpecialK's Avatar
+1. Sometimes the simple answer is correct.
46mm, filter
Magnifying eyepiece that doesn't vignette like crazy? Fabian Pentax Camera and Field Accessories 9 02-04-2012 09:44 PM
how to get this vignette effect? ajyp Troubleshooting and Beginner Help 11 10-30-2011 07:14 PM
vignette with telephoto, how? pete_pf Pentax SLR Lens Discussion 15 09-11-2009 07:32 PM
Creating a Vignette with a photo Pentaxtic Photographic Technique 8 03-29-2008 01:44 PM
All times are GMT -7. The time now is 06:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
