Hello, I'm new here, as you can see.
I'm a photography student and recently just started using a 35mm camera.
The only setback is that the camera I received has a broken wind crank. It does still pull up to open the cover, but the crank part is broken clean off. I finished a roll of film while shooting, released the film, but I clearly can't rewind it. It's also the weekend, so i have no access to the darkroom at school to process it. I still want to shoot more photos during the weekend.
Is there anyway I can rewind the film back in the canister?
Photo of my sad, broken crank
