Originally posted by Mo Doesn't the ZX-M have a tiny pentamirror viewfinder compared to the other MF SLR's? Mine's currently cased and on the shelf, but if I ever get around using it, I'll double-check.
It lacks lots of small features compared to the similar ZX-5n, but the biggest disadvantage would have to be the lack of a built-in flash.
As much as I like MF SLRs, I can't recommend this camera. The it's 'budget' design really impacts the overall build quality, although the electronics and photos are fine. The plastic mount is easily worn, so that's no good, either.
BTW, my favorite MF SLR would have to be the Super Program.
A) I've never had a problem with the plastic mount. Granted, I've only had the camera for 8 years.
B) Yes, it has a pentamirror viewfinder. It's still not bad. I prefer it to the pentaprism one on my MZ-5n. There is a slight black border around the scene that helps with contrast and framing.
C) You can't spare $40 for a flash? My Sigma 728AF works great and will even work well on the K10D when it gets here. (Probably more accurate than the P-TTL ones, if all the threads about them are right.) The 728AF will also do bounce flash. The popup on the Mz-5n won't. The puny flash on the MZ-5n is actually a disadvantage to me.
D) The build quality is exactly the same as the MZ-5n. The MZ-M is only missing a few additions (autofocus, spot metering, that silly panorama thing). And the light weight is a real benefit compared to the MZ-5n. The MZ-M and my 40mm pancake can't be beat as a pocket camera, even by the DSLRs.
