I have an ME Super that used to do that. Turned out the pressure plate in the film door was installed backwards so the door never closed properly. It was light tight when closed, but the latch never quite fully engaged, and the door would pop open on the slightest provocation. The fix was to turn the pressure plate around the right way, and un-bend the door latch which had deformed slightly from the pressure. It's been fine ever since.
That wasn't Pentax's fault. Pretty sure I screwed it up during an earlier repair; I had once removed the pressure plate while reattaching a broken film minder frame. Must have flipped it around during reassembly, having failed to notice that it wasn't quite symmetrical with respect to the mount points.
