09-06-2012, 12:30 PM   #1
Pentax K1000 question
Recently I bought a nice sample of pentax k1000 from ebay, but I see there are three version of this camera, japan, hongkong and chinese
On my camera it says asahi and AOCo on the prism, so it's not probably the chinese one.
On the bottom plate, there's noting there, but it seems that the name of where it's been assembled has been rubbed out.
On the lens, it says made in Taiwan, so can I assumed the the camera is also made in Taiwan?
09-06-2012, 01:27 PM   #2
Doesn't look like Hong Kong version I have.
09-06-2012, 01:44 PM   #3
what's the difference?
09-06-2012, 01:46 PM   #4
Ole
Ole's Avatar
We have a long thread on K1000 versions and a serial number database. You may want to check it out!
https://www.pentaxforums.com/forums/pentax-film-slr-discussion/51190-k1000-se...-database.html
09-06-2012, 01:54 PM   #5
I tried to post there first, it seems to be closed
09-06-2012, 02:30 PM   #6
Ole
Ole's Avatar
It's closed for new entries (the serial number database has taken over: Pentax K1000 Serial Numbers - Pentax Serial Number Database - PentaxForums.com ) but you should be able to figure out which variant you have from the information in the threads.
BTW, the manufacturing country of the lens has no bearing on where the camera was made.
09-07-2012, 03:23 AM   #7
Arjay Bee's Avatar
My made in Japan version has a serial number stamped on the base 1.5cm above the rewind release button- yours does not.
The sticker is much shorter than the sticker residue on your image with the single word JAPAN . Post a couple of images of the Pentaprism and I can compare it to the made in China version I have in the garage.
09-07-2012, 06:35 PM   #8
PPPPPP42's Avatar
As I recall the Chinese didn't have the AOCo and all the Japanese had "JAPAN" stamped into the body on the back so I'm going to say Hong Kong assembled, which is identical to the Japan ones unless you are a collector.
camera, k1000, pentax, pentax k1000, taiwan
K1000 Rewinder Question jack_d12 Film SLRs and Compact Film Cameras 6 06-11-2012 09:53 PM
K1000 and S1 question... beaumont Film SLRs and Compact Film Cameras 6 01-21-2011 09:31 AM
Pentax k-x and Pentax k1000 (old camera) question huskies4ever Pentax DSLR Discussion 14 08-23-2010 08:48 PM
Pentax K1000 wlank Film SLRs and Compact Film Cameras 3 06-24-2008 08:11 AM
zx-7 & K1000 Question dgmaley Film SLRs and Compact Film Cameras 9 02-07-2007 06:27 PM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
