02-28-2013, 01:05 PM   #1
Light seal material in bulk?
I have seven cameras to replace the light seals in, and I'd really rather not spend $10 per camera to get the seals. Does anyone sell these in bulk?
Charles.
02-28-2013, 01:33 PM   #2
Micro tools, Aki-asahi
02-28-2013, 01:35 PM   #3
Otis Memorial Pentaxian
Unless you have some sort of jig to help with the cutting, it is probably easier to buy the kits from Jon Goodman.
Edit: By cutting, I was referring to cutting strips from sheet material. Pre-made strips are a lot easier to work with, assuming you know the widths to buy.
(...cut my own from raw materials...ONCE...)
02-28-2013, 01:44 PM   #4
lsm
They have lengths of 2.5 mm ($6.50) and 1.5 mm ($2.45) that should do a few cameras.
02-28-2013, 01:54 PM   #5
QuoteOriginally posted by wombat2go Quote
lsm
2.5mm for mirror foam and 1.5mm for most everything else?
02-28-2013, 02:10 PM   #6
So far I have only used their 1.5 mm, and only on hinge sides.
02-28-2013, 04:52 PM   #7
Eric Auer's Avatar
I re-did the seals on my very old and battered Nikon FE with thin neoprene strips cut from a old mousepad. Stuck them on with Contact cement. Talk about cheap!!
But it works!
03-04-2013, 03:26 PM   #8
Lloydy's Avatar
I re seal all my film cameras using self adhesive foam that I buy from a craft shop, over here it's sold as 'Fabfoam' and comes in A4 sheets 1.5mm thick. I also buy sticky back black felt in the same size sheets for doing the ends of the film doors.
The trick is to use a rotary cutter, another craft shop item that once you have it you wonder why you ever used scissors, not a scalpel or a craft knife - they drag the foam no matter how sharp they are. The rotary cutter just cuts, right down to 1mm wide, I cut it thinner than it is thick. Use a good steel rule and one of those plastic cutting mats, it's just so much easier.
Clean the old crap out with cocktail sticks and lighter fuel. I then scrub the channel with my wife's toothbrush. She hasn't noticed the taste of Zippo fuel yet.
Peel the backing off the thin strips as you feed it into the channel, and push it into place with a cocktail stick. Cut to length once it's in place, cut the felts for each end, and the job's done. If you think you can't get the felts in the right position easily, lick the sticky side then position the felt. The moisture will allow it to slide a bit, then it slowly evaporates and sticks fully.
I've done about 10 or 12 cameras like this now, every one is light tight and free of horrible sticky crap, and I have enough foam and felt left for as many again
03-04-2013, 05:15 PM   #9
titrisol's Avatar
Location: In the most populated state... state of denial
Jon Goodman is a great guy, talk to him about your problem
he will probably cut you a deal and get you all the material you need for a decent price
He used to sell kits for 4-5 cameras for 10 bucks years ago, but people got "smart" and were reselling his kits
QuoteOriginally posted by ChopperCharles Quote
Charles.
03-05-2013, 07:46 AM   #10
Thanks, I'll take some of these options. Now I just need to find lenses for hte cameras as well...
Charles.
03-13-2013, 08:02 PM   #11
Does anybody know where I can find Jon Goodman's light seal kits?
I've been looking around for one quite awhile and either it's not floating around on the internet or I'm just plain ignorant.
I need one for my ME Super.
Any information would be greatly appreciated.
Thanks!
-Chris
03-13-2013, 11:25 PM   #12
Welcome to the forum. Jon deals directly by e-mail only at this point. I have his address, just not on this computer. If nobody chimes in in the next day or so, PM me and I will get it for you.
03-14-2013, 07:41 AM   #13
titrisol's Avatar
His email is: Jon _ Goodman at yahoo dot com
You can find insructions here:
Favorite Classics / Jon Goodman's Seal Replacement Instructions
03-14-2013, 01:14 PM   #14
Thank you, Steve!
03-14-2013, 01:14 PM   #15
QuoteOriginally posted by titrisol Quote
Thanks! I'll email him soon
light, seals
How long until a light seal needs to be replaced? LeDave Film SLRs and Compact Film Cameras 8 09-16-2012 05:25 AM
Adjust date in DNG Raw file, best method? Can it be done in bulk? WiseOx Digital Processing, Software, and Printing 3 07-05-2011 03:51 PM
Sigma 70-200mm f2.8 or Pentax 60-250mm f4 ? seal or no seal? TanGU Pentax SLR Lens Discussion 15 09-27-2010 03:12 AM
KM Light seal question ScotIslander Film SLRs and Compact Film Cameras 5 08-03-2009 11:02 AM
K-m in new body material pspentax Pentax News and Rumors 29 09-24-2008 08:10 PM
All times are GMT -7. The time now is 06:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
