Originally posted by vectrln The meter appears to be working okay since the LEDs appear to be changing appropriately with different lighting conditions.
If someone knows then correct me... Sounds like the "main board" is working or a good part of it, but the magnet is not firing?
Switch I300 might be dirty and is not connecting as "normally closed"... this is the switch that is supposed to allow 2nd curtain to release.
Switch I601 is the power board for the magnet switch and might not be working.
This begs the question... had there been a point where the camera was working properly from the time you received it and had it been slowly deteriating?
Or... was it acting funny from the first time you acquired the camera?
Verify if the meter is weird while the lens cap is covering the lens. Common issue of bad connections or "dirty signals" is if the meter still registers more than bottom red while - ISO/ASA @125-400 and lens is f@1.2-2.8. If the main board is bad, then the meter will show odd behaviors.
Test also if the it is not working in mirror lock-up mode... oops...
Originally posted by vectrln If I activate MLU then the camera appears to fire the shutter okay.
...so ya... not a sign the main board is out. The LX has a funny way of being different in than the mode from normal.
Depending on which version is your LX, Eric Hendrickson had informed me in the past that the first and second version of the main board was not available anymore. The current version would be of the later series that includes the Millennium and Titanium versions or ones commonly found with the wide collar release locks.
