I learned something this evening that really surprised me. As many of you know, the SMC and S-M-C Takumar lenses have a small pin on the mount face that provides an interlock for the aperture mechanism open-aperture metering. Many of you also know that the mount flange on Pentax M42 bodies is smooth with no screw holes. This is not the case with all M42 bodies. Many other brands attach the flange to the body with counter-sunk screws through holes drilled through the face. These other brands include Ricoh, Mamiya/Sekor DTL models, Zenit and who knows what others.
Have you guess the problem yet? That very tiny SMC pin has the potential to act like the infamous "Ricoh Pin" when mounted to a susceptible camera. Screw the lens on and the pin retracts until it comes to the edge of the counter-sunk screw hole. Try to remove the lens and...oh, oh!
No, my S-M-C 28/3.5 is not stuck to the Singlex TLS and for that I am thankful. From the look of things, the problem is only present for those bodies whose threads are cut such that the pin "lands" at the very edge of a screw hole. I don't know if it provides a degree of insurance, but I was wondering if there is any sense in taking care to retract the pin (move A/M switch to the M setting) before removing the lens from the camera. This might be a reasonable precaution for those of us having a mix of M42 lenses and cameras. Even then, there looks to be some protrusion.
