Originally posted by MysteryOnion Seeing as the foam is sticky... try slipping a piece of Scotch/cellophane/clear tape to cover the surface of the foam and then test the shutter... with no tacky foam to slow it down, it should operate as normal.
If not, then another problem.
I tried what you suggested and added some tape, but it's not helping the stuck mirror at all. I tried pushing the mirror up and down, pressing the shutter button, and nothing seems to be working
Originally posted by JuanEstrada Hi, it happened to me a few times... it seems like getting stuck in Bulb mode... I have a ME and here is what I did. instructions are in red.
I hope this helps.
Thanks for the suggestion. I have an ME Super which doesn't have a 100X option, I tried the 125X though. Still not working... *sigh* so much work just to even get the camera working, I haven't even gotten to experience snapping a picture with it yet
I may just have to put it off for a bit, save up some more, and then send it out for repair.
