Hello everybody.
I acquired an ME-F today and it was up and working. It looks quite battered and so I was doing some cleaning and some minor fixing. As seems to be the problem more often, the battery lid was kind of broken and taped-up. So I took the groundplate off and found out what the problem was, fixed it (as far as possible), though I'd have to make something like a new lid from aluminium or so. I also took off the old foam in the lid since it had gotten sticky and was falling apart. I put in some new foam and after that, the camera wasn't working anymore, meaning that the light meter etc. don't work anymore, just like the battery indicator.
I suspect that a solder-point has stuck to the foam in the lid and has been torn off the print. I don't know for sure though, but the print shows an "empty spot" where I'd expect something should have been.
Can someone tell me or give me a hint as to whether that may be the cause of the malfunction or does anyone else have a clue? A picture is attached, I've circled the "empty spot". I even tried soldering the indicated IC-pin to that spot but it didn't work, meaning I got a solder-connection to the spot and managed to solder a wire to the pin, but it didn't help.
I'm curious whether someone can help me because it seems a very nice camera to add to my collection, which until now only consists of a Zenit 12xp and this one
Best,
Rutger
