Originally posted by cooltouch Interesting. I agree with LessDMess on this one. I like to keep in mind that a camera's meter is going to interpret the subject as being 18% gray, so on that basis I would say your shot of the statue is somewhat overexposed. The camera doesn't know it's white marble. It doesn't even know it's white. It will see all that is in the metering area as 18% gray and expose accordingly. This is why you often need to overexpose when you're shooting predominant snow scenes, for example. It seems counter-intuitive, but if you don't, the snow comes out looking like mud.
Nonetheless, to me, the above scene is just slightly overexposed. There's burn-through in the face and the right shoulder/breast area. If I were to bump down the exposure just a touch, more texture would show up in the marble, which is my preference.
This is exactly how the camera should expose if there is no compensation. The 18%grey is a combination of black and white so aside from a little beenfit of center weighting, it will try to make the mix 18% grey, resulting I. Trying to elevate the black more because more of the frame is black than white.
---------- Post added 04-27-2015 at 07:58 AM ----------
Originally posted by Cuthbert The K2 looks like a mild spot while the KX more an average central.
The KX is what they call lower center weighted. It ignores the sky more than other cameras. If you want to do an experiment. Shoot a bright sky shot with the camera oriented normally, and a second upside down.
The one thing the lower weighted pattern also helps out with, is long tele lenses, because the KX mirror is a little undersized and you give up the top of the frame in the viewfinder when shooting with 400mm or more. This is likely why the pattern is lower center weighted. The sensor does not see the top
