06-10-2015, 09:56 AM   #1
cooltouch's Avatar
Winder LX Wiring Diagram?
Hey folks,
I recently purchased a Winder LX and it seems to me to be way noisier than a winder should be. So I decided to open it up this morning to inspect the gear trains to see if they might need some lubrication, and to inspect it for wear elsewhere within the winder. Well, as luck would have it, when I pulled apart the two halves of the case, three wires came loose from their soldered points -- the two wires (brown and black) leading to the accessory jack, and one long red wire that goes from the PC board to who knows where. I don't know what the red wire does, but I'm able to get the winder to operate partially dismantled and with the camera not hooked up to it. It will cycle and stop every time I turn the switch from off to "C".
I know why the brown and black wires separated because they're attached to one case half. But I don't know why the red wire separated because both its attachment points should have been internal.
So anyway, I could really use a Winder LX wiring diagram -- jpg, pdf, whatever -- a repair manual pdf would be great too. I've looked for both on the 'net and eBay, but haven't had any luck with either resource, so I thought I'd give the Forum a try. If you don't have a wiring diagram, but might have notes as to which wires go where, that would be fine as well.
Thanks for any help you can provide.
06-10-2015, 10:14 AM   #2
GPZ
GPZ's Avatar
This is one for the MX. Not sure how different they are. www.robertstech.com/stuff/PentaxWinderMX.pdf.
06-10-2015, 12:57 PM   #3
robry's Avatar
Hope this works
06-10-2015, 05:34 PM   #4
QuoteOriginally posted by cooltouch Quote
Here ya go - Boz's K-mount site has just what you need -
http://www.bdimitrov.de/kmp/technology/winder_LX/diagram.gif
[Edit: Oops - I should have refreshed the page before replying - I think I posted the same info as robry had already done.]
06-11-2015, 09:14 AM   #5
cooltouch's Avatar
Thanks very much, all of you! I'll print it out and compare it to the winder. See if I can figure out the solder points from the schematic. Incidentally, that's why I requested a wiring diagram, because often things like solder points are more obvious.
06-17-2015, 09:37 AM   #6
cooltouch's Avatar
I thought I'd follow up with a bit of good news. I contacted a fellow named Gray at uscamera.com -- an outfit that advertised the fact that it has a lot of parts for Pentax. Well, Gray was nice enough to email me a pdf of the LX Winder's Parts Manual, which included a wiring diagram for the Winder. Exactly what I needed. It also has a nice exploded diagram of the Winder. If any of you are interested in a copy of this manual, PM me and I'll send you a copy.
Just in case you might be interested, here's an image of the Winder LX's wiring diagram:
diagram, luck, lx, winder, winder lx, wire, wires
Lx Winder Performance Questions cooltouch Film SLRs and Compact Film Cameras 4 06-09-2015 07:29 PM
part for LX-winder dreamsof"LX" Pentax Camera and Field Accessories 2 02-26-2015 06:46 AM
For Sale - Sold: LX kit: body, 3 viewfinders, winder... Gnurps Sold Items 4 02-01-2014 06:19 PM
For Sale - Sold: Pentax LX & LX Winder - Just Serviced lewis44 Sold Items 6 05-22-2012 09:59 PM
All times are GMT -7. The time now is 08:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
