Originally posted by Macario I do not think the older cameras support P-TTL, so you will have to use TTL
No, Macario, you'll see that I wrote in my original post, both the ZX-L body and the AF 360 FGZ flash support both TTL and P-TTL modes. The P-TTL system was rolled out about the time of the late model ZX cameras, before Pentax began making digital cameras.
---------- Post added 07-30-2015 at 08:35 PM ----------
Originally posted by deus ursus Yes, deus ursus, that's right, thanks for posting the link.
---------- Post added 07-30-2015 at 08:39 PM ----------
Originally posted by narual I've used my modern WR P-TTL flash with my ZX-L. It seemed to work OK. I've only shot one roll of film with the camera, though, and I only used the flash for about 5 shots on that roll... so not exactly exhaustive experience.
I'd go plain TTL. It sounds superior to P-TTL to me, if the pre-flash or whatever it uses doesn't cause a problem for you.
Narual - Thanks very much for relating your experience. I just shot a picture with the P-TTL mode on the camera, as the flash defaults to that on start-up and I didn't feel like taking the time to change it. Actually I didn't even notice the preflashes (the P-TTL uses preflash to set the exposure). I'll probably take a couple shots with TTL (no preflash used, the off-the-film exposure sensors just cut the flash off when there has been enough light transmitted) and see if I notice any differences.
---------- Post added 07-30-2015 at 08:41 PM ----------
Originally posted by Swift1 If you don't already have a flash, then maybe go TTL because you can get the AF-280 or AF-500 for very little money.
If you already have a P-TTL flash, it will work great.
I think the ZX-L supports wireless when used with the AF-360.
Swift - Thanks for your help. You'll see in my original post that I do indeed already have an AF 360 FGZ flash. And yes, that flash and the camera will support wireless.
