08-29-2015, 11:54 AM   #1
Jean Poitiers's Avatar
Mirror "locked up" on a ME Super ...
Bonjour,
I picked up last month a nice cosmetic ME Super with M 50/1.7 from my thrift store and it seemed to all just fine ... just needed batteries.
Yesterday I was triggering the shutter and the mirror "locked up" in the up position ... and would not return to its normal position. All is locked up now ...
I changed the batteries and tried the different positions on the control dial but to no avail ... does anyone have a suggestion ?
Thanks in advance for any help ... Cheers, J
08-29-2015, 12:00 PM   #2
mattt's Avatar
Does the shutter cock operate normally/correctly? There is a little piece of spring steel that breaks off after typical wear and tear and it can jam up the inner bits easily.
08-29-2015, 12:17 PM   #3
QuoteOriginally posted by mattt Quote
Thanks for your question ... shutter crank/cock will no forward anymore.
All is seized up ... maybe it's that.
08-29-2015, 12:18 PM   #4
Not a Number's Avatar
Mirror bumper turned to glue/tar? If that's the case you should be able to lower the mirror by gently prying on it. Use something that is less likely to scratch or break the mirror like a toothpick or finger nail.
08-29-2015, 12:18 PM   #5
mattt's Avatar
no, i think it is related to the mirror not going down at this point, I was asking about before the mirror got stuck... did it operate normally?
08-29-2015, 12:25 PM   #6
Yeah, Matt ... Everything worked fine and normally before it seized up ... that's why I am a bit puzzled here. Never seen this.
I was looking at this ME Super to see if I could run a roll of B&W through it ... I have 2 or 3 nice ME Super's and I am trying to decide which one to send to Eric H. and which one to leave be ... maybe this one will be assigned to a shelf in my office.
---------- Post added 08-29-15 at 21:27 ----------
Thanks for your suggestion. The bumper does not seem that bad. I tried to pull the mirror down via fingernail but it went back to the "up" position again after releasing it ... a bit confused here.
08-29-2015, 05:06 PM   #7
QuoteOriginally posted by Jean Poitiers Quote
A couple weeks ago I received an ME F from an eBay seller that arrived ~exactly~ that way -- I had to send it back.
08-29-2015, 08:20 PM   #8
It looks like the ME Super has a electronic shutter that will work mechanically at 1/125 sec. Try setting the speed to 1/125 and see if you can get it to finish cycling through the shutter release sequence - with and without the battery.
Pentax-manuals.com has a service manual for the ME Super. If it asks for a password use "Pentax"
http://www.pentax-manuals.com/manuals/service/me-s_sm.pdf
Seems like there is a friction washer made of calfskin that's used in the "dumper lever assembly" (part of the mirror assembly). I would imagine if that dried out or rotted it could cause problems.
08-30-2015, 04:46 AM   #9
hks_kansei's Avatar
This seems to be a pretty common fault with the ME and ME supers.
Maybe the MV/MG as well?
A friend has a few MEs that he has bought over time, and I think of them all only one was functional, the rest all had this issue.
An old trick that may work is to just thump the bottom of the camera onto the palm of your hand, this can let the camera at least finish the exposure.
But, while sometimes it will work fine afterwards, other times it might just lock up again the next shot.
09-02-2015, 11:58 AM   #10
OK ... thanks. I will check out the manual. Much appreciated, J
---------- Post added 09-02-15 at 20:59 ----------
QuoteOriginally posted by hks_kansei Quote
Thanks for the suggestion, but I had already "spanked" it pretty hard with my hands to the point of some good pain ... nada. Cheers, J
batteries, bit, camera, mirror, position, shutter
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
Spotmatic F mirror staying in "up" position 313 TUxedo Film SLRs and Compact Film Cameras 15 11-16-2014 12:07 PM
ME super: can I use "M" lens in "auto" setting. treetoile Troubleshooting and Beginner Help 4 03-25-2013 10:03 AM
"Hanging mirror" on my 67 - who will help me out? Rense Pentax Medium Format 11 10-31-2012 05:48 PM
K5 mirror "stuck up" or "flop"? jpzk Pentax K-5 & K-5 II 6 09-09-2011 07:20 PM
All times are GMT -7. The time now is 10:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
