Originally posted by arnold Do you mean you have to wind it several times to load the shutter so it will fire when you press the button? My ME Super needed two winds if it hadn't been used a few says. I opened bottom plate and noticed delicate springs and locking levers were slow in action. I gave a careful spray with carburetor cleaner to dissolve stickiness, and that cured the problem. If you hold the camera to your ear and slowly cock it, and hold the lever, you will hear the click of the lock eventually. It should of course be instant..
Well, after maybe 3 days I have to wind it about 4-12 times, it used to be 7-9 times before I just decided to wind it a bunch of times, and take pictures whenever it was ready, and I was thinking about taking the bottom plate of and cleaning it, but I need to find the right screwdriver for those teeny-tiny screws, then I need to put them somewhere where the kitten won't play with them... i'll try spraying carbureter in there, I just have to find it
---------- Post added 10-26-15 at 12:08 AM ----------
Originally posted by demondata I have non-working ME Super that you may be able to use as a parts source that you can have for the price of shipping, may be worth it depending on where you are located.
I will try stuff on mine, but that's very helpful of you, thanks
---------- Post added 10-26-15 at 12:14 AM ----------
Originally posted by titrisol Thanks, just fixed the other stuck mirror it had
(I guess hitting it on the sidewalk doesn't work always) all I did was push the shutter down lightly, and POOF, it comes down... accept the film advancer didn't get fixed, but that's a problem for Kurt's Camera Repair to fix...
