The
Cosina C-series was the first K mount series offered in Germany - as
Cosina and also (slightly cheaper) rebadged but absolutely identically as
Porst.
The
Cosina CS-2 (the CS series was the follower of the C series) was my first K mount camera (but the name was
Porst compact reflex OV), with the Porst 2.0/50mm (also from Cosina).
This was my entry to the K mount world, which finally made me a kind of Pentaxian (in late summer of 1981).
I had choosen Porst because of the K mount, already having in mind to switch over to original Pentax cameras and lenses at some point in development of my income. Specially the amount of different lenses available from so many companies made this a no-brainer for me.
The
Porst compact reflex OV (=
Cosina CS-2) was feature-identical to the
Pentax ME, the only differences in built were the shutter (cloth instead of metal), self-timer (electronic instead of mechanic), and plastic casing instead of metal. There even was a winder/motor available with 2 frames/sec. And it came for less than half the price of a ME. I myself soon replaced the Porst/Cosina lens by the
SMC Pentax-M 2.0/50, which turned out to be slightly better (coatings). And some time later, I sold the Porst/Cosina and bought an used
ME Super. And this was just because I was sometimes missing the possibility of pure manual exposure control.
But I heard from others that they used these Cosina/Porst bodies for more than a decade and shot many thousands of pictures, without any problems. So it seems, despite the plastic body, that they were quite durable.
@BigMackCam
Quote: For anyone who owns one of these, I do have a question re the viewfinder "mount"... Being very much a budget camera, there is no viewfinder surround / eye cup supplied, and - since there's no diopter adjustment on the viewfinder - I'm going to have to wear my glasses to shoot. Hence, I'd like to fit some sort of rubber-surround eye cup to avoid scratching my glasses. My question: is the viewfinder mount standard - i.e. can I fit a Pentax (or other brand) eye cup, or do I need an original Cosina accessory?
Does the frame of the VF look as if it was prepared for the use of an eyecup? Mind that in the (very) old days, most of such assessories were to slide vertically onto the frame/mount. Pentax changed this to a slit all around the frame and flexible (=rubber) eyecups with the M series. Also from K to M series, they changed the size of the frame. If you have not found a solution, please post the exact size of the frame (mind a possible slit). If it is the same as with the Pentax DSLRs, any cup of the Pentax SLRs from M, A, and P series should fit. If not, maybe some forum member can compare with K series viewfinders.
EDIT:
Be aware that
original Pentax rubber eyecups for the SLRs will now not only be quite old, but may also have become stiff . I got a used one from eBay which had lost all of its flexibility and would detach by itself when touched.
