Originally posted by Treker I just had a look at mine, if the back is open it will only fire at 125th of a second. The best way to check operation is to set the time to man. 1 second, remove lens and fire the shutter, you should be able to easily see the pressure plate from the front.
I did set it to manual and bulb, and took off the lens and looked inside. I did not see the pressure plate, just the shutter leaves. I tried it with a test roll of exposed film and did not see the film exposed through the front either. The shutter sounds normal and the shutter looks like it moves normally up and down, but no light is coming through! I sure wish it could be a simple fix, but it probably is not. Not worth it to me to have it repaired. Otherwise everything on the camera seems to work as it should.
