03-28-2016, 12:47 PM   #1
Eyewanders's Avatar
Broke my FA31 lens hood - Grrrrrrrrr
It wasn't until I began using the FA31 more and more on my film bodies that it *truly* became my most used and favorite lens.
Yesterday evening, while mounted to my MZ-S stuffed in a canvas satchel, it took a fall landing lens-front first. Seems one of the points where the hood is attached to the front element barrel was sheared off by the impact. The hood now wobbles hugely at the end of the lens. The lens itself seems to perform fine still, after quick checks at a couple different apertures and at close and infinity focus, though focus is impeded slightly when one side of the hood slides down and just touches the edge of the focus ring, creating a very slight bind. It will probably be ok (assuming whatever popped or sheared of isn't lodged elsewhere in the assembly - nothing is rattling around that I can hear) but the large amount of play and wobble now is GIGANTICALLY irritating. Just a bummer. Needed to vent.
03-28-2016, 02:09 PM   #2
go to BH get a rubber collapsable lens hood, it will work just as well, protect better and you won't have to take it off when you don't need it or need to store it.
03-28-2016, 02:59 PM   #3
monochrome's Avatar
EBay. Pretty penny, but hey.
FA 31 black hood NIB.
03-28-2016, 03:46 PM   #4
gofour3's Avatar
Try Eric he may be able to fix it.
Phil.
03-28-2016, 05:57 PM   #5
Eyewanders's Avatar
Was thinking about Eric. I don't even know how to get it *off* were I to switch to a removable - any know? I've never tried. Judging from the diagram another PF member sent, it's essentially part of the entire assembly (not that I'm a whiz at schematics).
fa31, fa31 lens hood, focus, hood, lens
FA31 Fall Down Go Boom :( - Lens hood wobble Eyewanders Pentax SLR Lens Discussion 3 03-29-2016 06:08 AM
FA31 cheap filters for lens hood and how to remove glass dtra Pentax Camera and Field Accessories 7 06-09-2015 06:26 PM
Does this hood fit FA31? Daniel.J.B Pentax SLR Lens Discussion 18 05-15-2014 07:22 AM
Hood for FA31 Ltd nicoprod Pentax SLR Lens Discussion 12 02-22-2014 10:04 PM
Diopter level and lens release button broke... How's my weather sealing? Vicboy Pentax K-5 & K-5 II 3 08-15-2013 05:25 PM
All times are GMT -7. The time now is 11:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
