I obtained this camera body when I bought a lens that happened to be sold with it. It appears to be in good shape in most ways, battery and film compartments are pristine, and very little in the way of obvious wear can be seen. Really the only problem issues noticeable before putting batteries in it are: (1) the spring that raises the built-in flash seems to be broken or disconnected, and (2) some of the plating on the outer edge of the metal lens mount ring is gone, allowing the underlying metal to corrode slightly in those areas.
When I put batteries in it, both the topside display and the one inside the viewfinder seem to work perfectly, according to the manual for the camera which I downloaded. The shutter didn't seem to fire, with either the back closed or open. I thought that it might not fire unless film was loaded, so I put inserted a roll of film, closed the back, and the camera winder loaded it the rest of the way, until the "1" (for the first exposure) was displayed. But again the shutter did not fire, and, presumably because it did not, the winder did not advance for frame "2."
Furthermore, if the internal flash is held in the up position, it doesn't fire when the shutter button is depressed, and an external flash doesn't fire if one is attached to the hotshoe when the shutter button is depressed.
There is a very brief buzz or whirr sound when the button is pressed, but the shutter isn't tripped, and anything else the tripping shutter would cause, like the flash, or the subsequent winding of film don't happen.
[I don't own an auto-focus lens, so I can't check to see if the auto-focus capability works with AF switched on.It does seem to recognize when a manual lens is focused.]
Is this shutter failure a common aging issue among Zx-5s or their close kin? Is their a dyi fix, or only one an advanced technician can perform?
