Originally posted by ctrout I would imagine that the model of phone that it is used on might affect the accuracy. I would also assume that the app somehow taps into the meter that the phone's camera uses. Can anyone comment on this? I guess that the best way for me to see if this will work for me is to just get out there with a known accurate meter and compare. I tried it indoors around the house briefly and the phone app seems to be 2 or more stops off compared to the meters in a couple of my Pentaxes. Maybe the accuracy would be better under better lighting conditions.
I just tried it again in the living room. The meter says EV3 When I expose according to the meter, my 7D2 is underexposing by exactly one stop. It seems to be pretty consistent so I'll do some more testing in other light conditions in the next few days and report back. If it proves to be consistent across varying light levels, I'll move up to trying it with my 1958 K model and my SV and see how it works out. This is going to be a blast if it ends up working out.
Edit again to say that the 1 stop underexposure is based strictly on where I like to see the histogram. As it turns out, the meter app is giving the exact same exposure as the 7D2 is giving in AE mode, right down to a third of a stop.
Yup - as you surmised, they can be quite accurate, phone depending. They're also generally much more sensitive to the angle of light hitting the sensor. There are a few "brands" of diffuser domes made to fit over various phone models which help with. One is called Luxi which I've read is pretty good though I've no experience with it directly. There's also an actual meter (for iPhone only I think, but I could be mistaken) which I believe is called Lumu... or Lumo... or something like that, which is an actual meter that plugs into the phone with it's own app. Reviews of it are good.
For my money, it's all just too fiddly. I still prefer a real meter or sunny-16.
