Dear Board,
I recently won a P30T w/50mm f2 SMC-A in an auction. The camera appears to be in good condition. I put in fresh batteries in it and it turns on. The meter works and appears to be accurate when compared to other known good light meters. All the possible functions, P. AE, and M work and values can be changed.
The problem is the shutter will not fire. It works fine to the halfway detent to make the viewfinder meter indicators light but it will not fire. I'm not sure if the problem is with the shutter or the film advance lever but I would appreciate if anyone has any ideas on a simple fix or should I look for another one?
Regards,
Tim Murphy
Harrisburg, PA
